DIY Water Cooler
Just finished a DIY water cooler for my PM256.
I used a carbonizer unit and adapted the SS tank on it for the water storage tank. And used a auto AC evap for the radiator. I used quicke disconnects on the torch and coller so when I want to put it away I can disconnect each and reconnect the ends so nothing leaks. Also this was handy to attach a pressure gauge to set the pump pressure. I drilled out the end of the motor shaft and welded in a 1/4" shaft for the fan to attach for cooling both the water and motor.
Have fun
tom
Everlast PM256
Millermatic 180
Longevity Force Cut 80I
13" metal lathe
Small Mill
ect, ect.
