Results 1 to 11 of 11
Thread: clamping arms
    Default clamping arms
    Here is a set of articulated arm clamps I welded up. The material used was 1’ ball bearings, 3/8” plate, and ¾” round stock for the construction. 3/8” bolts to tighten each clamp when in position. I welded up different ends for either clamping to my table or the material I am going to weld. Bolts, Vice grips. And angle iron ends shown in the pictures.
    Have fun
    Tom
Name:	clamp in action (7) A.jpg
ID:	2698   Click image for larger version.
Name:	ball clamp.JPG
ID:	2697   Click image for larger version.
Name:	clamp in action (6).JPG
    Everlast PM256
    Millermatic 180
    Longevity Force Cut 80I
    13" metal lathe
    Small Mill
    ect, ect.
    i love that, how stiff is it when you tighten the ball joints? you should patent that
    Thats pretty awesome. It's a giant set of helping hands.
    Did you use a lathe to modify the bolts so the bearing would set in the end?
    listen jester i know it seems like its to soon but i want to get married that way you and i and the clamping arms can live happily together
    Jan 2010
    Chugiak , Alaska
    Quote Originally Posted by parkour View Post
    I use the Helping Hands to solder wires together, recognizedthem right off. Looks like a really useful tool. I’ve never seen one that big before.
    ____
    Ray
    support@everlastalaska.com
    www.everlastalaska.com
    877-755-9353 X207
    I did use a lathe but that could be done with a drill press or even in a vise. just cut the head off and drill the end with a small bit first then go bigger to get the dimple as shown.
    The arm holds very well this picture show one arm holding a 1-1/2" square tube and the black clamp suspended in the air with no other support.
    have fun
    Tom
Name:	clamp in action (1) A.jpg
    Everlast PM256
    Millermatic 180
    13" metal lathe
    Small Mill
    ect, ect.
    Jan 2010
    Chugiak , Alaska
    Did you get the ball bearings out of a CV joint or something?
    This is too cool, I’d pay money for something like this, ifit wasn’t an arm and a leg$
    ____
    Ray
    877-755-9353 X207
    Very nice. The Giant Helping Hands. If they where on the market I am sure they would sell. I have a smaller set for soldering and a bigger set for circuit boards. Never thought about a set for welding.
    Neat idea Tom.
    Default 1" balls
    here is where I bought the balls
    http://www.vxb.com/Merchant2/merchan...e=BearingBalls
    but they are cheaper here
    http://www.mcmaster.com/#9528k33/=d26ur8
    have fun
    tom
    Everlast PM256
    Millermatic 180
    13" metal lathe
    Small Mill
    ect, ect.
    I notice a taper on the dimple end, where the bolt head was- is that to accommodate the weld?
    Do you have a closeup of the female end, on the 3/4" stock?
    Very sharp!
    The end of the ¾” round stock is the same are the ½” bolt. The dimple is made to fit on the ball better for welding. Without the dimple the ball just slides away from the end of the bolt or arm. Just think of it a trying to mount a ball on a vertical rod. The dimple makes a cup for it to sit in. Even though I used a lathe to make the dimple the shape was from a drill bit. Hope that helps
    Have fun
    Tom
    Everlast PM256
    Millermatic 180
    13" metal lathe
    Small Mill
    ect, ect.
