Page 1 of 3 123 LastLast
Results 1 to 20 of 47
Thread: Mystery Welder Revealed: 2012 DIGITAL POWERTIG 210EXT TIG/STICK welder
    Default Mystery Welder Revealed: 2012 DIGITAL POWERTIG 210EXT TIG/STICK welder
    Guys we were thinking about keep things under wraps a little longer. But as things would have it, we just couldn't wait...(Like kids waiting for Christmas ourselves a little bit maybe.) Really, with the success so far of the 250EXT, we felt things were right for an early sneak peak of this unit. Final specs are being ironed out. But we have decided to offer it at an introductory price of 1799.00 to get things kicked off. Yes, we'll take orders...so if you wait around, the first shipment may be sold before it arrives...but if you order early, well, we can work to increase our initial order. The welder has as of now 35% duty cycle at 200 amps. And it WILL have a thumb amp control on the torch as well as an OPTION. In reality the 200 EXT referred to in the contest is the new 210 EXT. We wanted to undersell it, and surprise you, but now....Surprise! 10 extra amps will solidly get you into that 1/4" aluminum range with a little breathing room.
    And for stick operation, this is our most advanced yet with digital hot start set capability as well as a voltage reduction function.
    So, here it is:
Name:	Everlast 210EXT 2.jpg
ID:	4091   Click image for larger version.
    Very nice!!
    Hope I get it!
    Looks good much smaller then 250ext. Does it include pedal or torch control only? Can we use the 40% from prior contest? Any idea of date it will be in stock?
    Bill
    Order will be shipping out end of January, boat is ususlly takes 2 weeks to arrive to USA
    Oleg Gladshteyn
    67cuda,
    It includes standard, a new pedal and 2T/4T remote torch control features. The adjustable amp control on the torch handle is a separate order (for now)...Its an either-or, one at a time set-up. You cannot use both at the same time. However, I believe the 2T/4T function is available as well on the finger amptrol torch. If you have a pedal, it will not preclude you from using a finger control torch..the unit sees no difference, and recognizes it the same as a foot pedal.
    That is an awesome looking welder. What are the dimensions?
    Wow, amazing. Will there ever be just an arc welder with the settable hot starts and arc force control? Cause that could prolly be pretty nice to have on there.
    Gabe
    everlast power arc 200
    lawn mowers
    Looks good. Any idea on input power requiremets? (amps @ 240V)
    Quote Originally Posted by bobwills View Post
    Bob,
    That would be the PowerArc 300...in stock NOW! 220v single phase.
    The dimensions I have now are a rough estimate, give or take a few mm's. 17x8.5x17". Weight about 35 lbs.
    Can't find the PA 300 on the Everlast products page? Where to look?
    Everlast PowerArc 300
    Everlast PowerArc 200
    Everlast PowerPlasma 70
    Hobart Handler 125 EZ
    Lincoln Tombstone AC
    Lincoln Tombstone AC/DC
    O/A outfit
    Honda 11K generator
    GWD,
    Not listed yet. Sorry. We are working on it, but it takes a while to build up new pages, and add in all the specs. I will have the new PA manual up shortly though..hopefully by this weekend.
    oh so the power arc 300 has it. Nice addition. How much is it just wondering. Wont be able to aford it though cause just got powerarc 200 not too long ago.
    Gabe
    lawn mowers
    This is one good looking welder, I cant wait to win it It would be nice to see a demo video to see how to use all of those membrane buttons, does it have a memory for different settings?
    Miller Challenger 172 Mig
    Wade Mortenson
    How does this compare to the 200dx as far as specs goes? I may list my 200dx for sale and upgrade with my 50%off coupon.
    Sean,
    It's late tonight, but I will say this. The 210 offers more, especially for running on your generator. It does only have a 35% (as of now..hoping for more with a couple of minor changes to venting) duty cycle at 210 amps. It has all of pre/post, up/down, start/end features of the EX and 256. It also has wave form control additionally. It also has improved stick functions with hot start ajustability. It has 2t4t with an available torch amp control (optional). Memory as well.
    I like the curves that the design has added to it. I think the darker handle matches the unit better also. Are all the settings digital rather than guessing on the knobs like the 256?
  18. Default
    The Duty Cycle is now at 40% and in order to do this there has been a slight modification to the mold design for the front plastic bezel.
    Cheers
    EVERLAST CANADA
    www.everlastwelders.ca
    www.titanwinches.com
    905 637 1637
    Sean,
    ...and 40% duty cycle to boot! I think I'm just now starting to understand the buzz about this machine!
    hey guys, Im up here in canada and its currently -32c just thought I would mention that haha. Anyways I've been on the canadian site and theres not much going on, I only found out about this 210 by cruzing this forum. Just wondering if anyone knows about the availability of the 210 up here in canada. thanks!
  1. Power I Mig 200 MIG STICK WELDER , how high should the amp gauge read on stick side
    By Tim L Rogers in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-22-2016, 04:42 AM
  2. NEW 2013 EVERLAST PowerTig 255 EXT AC/DC DIGITAL TIG WELDER
    Last Post: 12-13-2013, 09:48 PM
  3. NEW 2013 EVERLAST PowerTIG 185 ACDC TIG / STICK WELDER
    Last Post: 12-24-2012, 12:43 AM
  4. 2012 Everlast PowerArc 160STH Dual voltage stick welder
    Last Post: 04-26-2012, 01:57 AM
