Results 1 to 9 of 9
Thread: finished plasma tracer
    Smile finished plasma tracer
    this is 1/4 plate it is cutting -well got my aluminum i needed and my foot switch . works great all need to do is get a flat piece of plastic to lay what i am tracing on since got darn welding spatter on my table and gouges kept snagging on the stuff while tracing . traced a piece and turned out exactly the same .installed a long bolt at one end as a counter balance weight holder , have some strap steel coming to do the slats for the table . the tracing piece at the end will be replaced with a shaft with a roller ball on the end here is the pics Click image for larger version.
Name:	engine rebuild and installs 004.jpg
ID:	6989Click image for larger version.
Name:	engine rebuild and installs 005.jpg
ID:	6990Click image for larger version.
Name:	engine rebuild and installs 006.jpg
ID:	6991Click image for larger version.
Name:	engine rebuild and installs 007.jpg
ID:	6992Click image for larger version.
Name:	engine rebuild and installs 008.jpg
    Oh yeah, that's what it's all about. You've got plenty of range in your setup to trace a very large piece too. Everything working smoothly for you now?
    yes works great only thing i need to do is put a bolt with a nut at each corner of plasma table since my bench's are not level the farthest bench is like 1/4" or more lower than the closer bench in pics . the only thing i wish i did was make it over 48 inches one way so could rip cut 4x8 sheets
    Golly, Rod. Just how much space do you have at your shop?!? I would love to have the luxury of being able to work with such large sheets ....
    around 2500 square feet
    That's a pretty good size shop. Lots of space for your tools and creations!
    Awesome job Rod ... looks gr8!
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    and a bunch of other tools
    Looks like a simple tool will do lots of work for you.
    What is the gap height you are cutting? I think you need abigger one to reduce the dross.
    Everlast PM256
    Millermatic 180
    Longevity Force Cut 80I
    13" metal lathe
    Small Mill
    ect, ect.
    Looks good. Do you think using one of the wire standoffs would work for this to keep your torch at a consistent distance?
    I am thinking about making a steel tailor type cantilever CNC plasma.
  1. Finished my Welding cart
    By Ron of Va in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 11-16-2013, 05:07 PM
  2. Finished my first Tig Project with pics
    Last Post: 04-15-2012, 03:35 PM
  3. Just finished hooking up the 250EX today
    By brad3579 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-13-2012, 08:00 PM
