Power Pro Tig Pedal Issues
Today was the first time I utilized the PP 256 supplied Tig Pedal and here's what happened. Setting of 125 Max amps #6 cup, 3/32" Thoriated etc. etc. on 1/8" steel test piece. Installed the pedal and the PP256 lite up beautiful, varied the pedal and I could see the current increase/decrease, let off the pedal and the ramp down and post flow worked as set. Hit the pedal again but this time I wasn't able to get what appeared to be the full range of the pedal as I had done earlier. Tried it again and again and I wasn't able to get current to fully change from zip to 125 amps.
I took the pedal off and removed the bottom cover. What I found was the cog belt was jumping the teeth on the cog wheel and I wasn't getting the 270 degrees of movement on the 50k ohm pot. It would jump a cog or two if it the pedal was released quickly. It seems that the cog belt maybe TOO stiff and when the pedal is released quickly it jumps around the cogs on the pot shaft.
I have it disassembled on the garage workbench awaiting suggestions for the correct repair.
Anyone experienced this and have a corrective solution other that don't release the pedal quickly.
Everlast PowerPro 256
Everlast W300 Cooler
Everlast Cart 250
Millermatic 211
Spoolgun 100
Miller HD Cart
Victor 315 Torch sitting on a Harper 830-86 cart
