Originally Posted by
everlastsupport
On the points. Start in the middle front, look a little left and look a little down for 4 light (sky) blue small round discs. They are right in front them, between you and the blue parts. The board will have a 1.5x2" black or dark grey plastic cylinder on it, behind the blue caps. They are on the edge of the board closets to the front edge.
I took some pics of my PP256 when I first got it and had the cover off to tighten the inside terminal for the plasma pilot arc post.
Does this zoomed-in, and cropped photo show the location your describing? Also, exactly, how do you go about adjusting these points? My 256 works fine, just curious.
Tony
Everlast PowerPro 256
AC225 "Tombstone"
HF 20 ton press
Rotary 9000# two-post
