TIG Welding Articles
  • Advantages of TIG Welding Machines
Before talking about the TIG welding advantages, let us understand Tungsten Arc Welding (TIG). In TIG welding an arc is created between a non-consumable tungsten electrode and the metal being welded.    Read More...
Gas Tungsten Arc Welding (GTAW) is referred to in professional circles as Tungsten Inert Gas (TIG) welding. This is an arc welding process that uses a tungsten electrode to create the weld.    Read More...
Welding is the process used for fusing metals. There are different types of welding like arc welding, gas welding and resistance welding.   Read More...
The TIG welding machines requires the use of the right tungsten electrode for giving good results in welding. This will be useful as it results in giving a neat weld.   Read More...
TIG stands for Tungsten Inert Gas welding process. Tungsten metal is steel gray in color and has the highest melting point.   Read More...
In order to understand how to perform TIG welding in your welding garage you need to firstly understand what welding is and how it works in general. The basic background knowledge is very important initially to start practicing anything for that matter.   Read More...
At the beginning level of TIG welding, you'll find a lot of interest in welding Aluminum. Many people have no idea where to begin. An important part of welding Aluminum is understanding it requires AC output with High Frequency for starting the arc   Read More...
