Replace a PT-31 with a S45?
Well our school it building a SAE mini baja car and we were using my old mosfet Lotos branded CUT40D well till somebody smashed the torch :( and not wanting a PT-31 again I bought a 25foot Trifamet S45.
So seeing your forums are the best of all the chinese plasma cutter companies I ask these questions, I bought this back in the day (like 08') when all the chinese cutters were blue boxes. And I know from opening the cutter it was made by Chiry from before the fake mosfet problems.
So the question I pose is how would one deactivate the HF start? I see a two wire lead coming from between the Shunt and the Torroids leading down to near the flyback transformer on the lower board with spark-gap and solenoid relay.
If I unplug this lead the HF start is deactivated. But I doubt this is completely correct.
What would be the correct or best way to deactivate the HF start?
Now I've made a coupler from the female fitting on the S45 torch which I believe is a 1/4" straight british fitting to the fitting on the CUT40 which I think is some kind of argon or other gas ball seat fitting.
The second question is what do you think these fittings are? I know they are mostly all the same on the PT-31s
And the third question is, after attaching the S45 torch and soldering on the 2 pin fitting, and attaching the return lead to the ground fitting. I then disconnected the two wire lead from the first question and I trigger the torch. IT WORKS!!! :) but only for a second :( the pilot arc is only up for less than a second. If I am able to get the pilot arc start the arc to the work, the S45 torch cuts beautifully! If not there is the 5 second torch post flow, now too the question.
What is the usual time duration for the pilot arc? Is the pilot arc for a CUT40/50 cutter with the S45 torch momentary like this ?(its under a second right now) or it is continuous? The second part of the question is there a way to change the time for the post flow? I know there are switches for manual/auto or 2.5/5 seconds now. I can see two variable resistors on the end of the top board of the cutter from near the location to the leads from the amp control potentiometer.
Now I know this is not a Everlast Plasma cutter but this seemed like my best bet for an answer. I'll get pictures of the internals in a minute.
-Gabe
RMU baja
