3 Attachment(s)
Everlast Super200P died. Performed "diode-ectomy". Now it's welding again!
My Super200P's welding function bit the dust while pushing it welding some very thick aluminum in the middle of last week. I burned one diode out of the high current diode array (24 diodes in this array, affixed to the massive air cooled heat sink.)
The symptom was, the welding arc just quit. The cooling fans and the gas solenoid kept working as they should. The "fault indicator LED" light also turned on (has a symbol next to it that looks like a lightning bolt.) Mike (everlast support) helped me troubleshoot it. When the machine was switched on in TIG mode, the fault indicator LED would turn on once an arc start was attempted. In stick welding mode, the fault indicator would glow immediately. There was no high frequency arc starting, and scratch starting was ineffective as well.
I troubleshot it as a shorted diode, in the 24-diode array. This is located on the left side of the machine (to your left while looking at the front) at the bottom of the heat sink. These diodes actually look like transistors (three pronged little black silicon things, clamped to the heat sink.) But looking up their part numbers, they are actually "dual diode packages."
(here is the datasheet on them: http://media.digikey.com/pdf/Data%20...FAF30U60DN.pdf )
Attachment 2394
Mike (everlast support) was super helpful diagnosing this, but perhaps a previous job experience I had in electronics industry a long time ago (I worked for an electric guitar amplifier manufacturer) didn't hurt either. I found the shorted diode by testing the continuity between the pins of all the "transistor lookling things" with my multimeter. The failed diode basically had a short (zero resistance) between two pins. Because of the way they were wired, a whole bank of the diodes all measured the short when they were installed, but after I removed the circuit board and did some further troubleshooting, I was able to narrow the short down to just a single diode.
My fix, at least at this point, was to simply remove the failed diode, (and other "shared diode packages" like it in the other diode circuits, which I thought were mostly likely to fail.) There were 8 circuits in the diode array, each driving 3 diodes in parallel. My temporary fix is to have each circuit drive 2 diodes, both in the same pacakge (to hopefully minimize the change of "thermal runaway", more info on that in a bit.) The 3rd diode in each circuit was from a shared dual diode package (which are the ones I removed.) You can read about the problems of putting multiple diodes in parallel here - (but basically - it's generally not a good idea):
http://wiki.answers.com/Q/Can_you_pu...he_double_load
Here is what my circuit board looked like after removing the "shared" dual diode packages, when it was still removed from the machine:
Attachment 2395
It remains to be seen whether this solution will actually increase reliability of the machine or not, but I can say that it fixed the machine, and it's back up and running. A better fix would be to replace the multiple parallel diodes with single diodes, with an equal or greater combined amp rating than the sum of the diodes it replaced. I am considering going this route at some point, but for now it's great to have my machine back up and running!
Attachment 2393
(Can you spot where the diodes were that I removed?)
The cool thing is, I managed to diagnose and fix this primarily by myself (and well, with some help from Mike over the phone, but I was the only one who touched my machine, and didn't need to send it out anywhere.) It didn't even take all that long - I had the problem figured out in less than a day, and after some research about the problem and fix, I was able to implement a repair solution (even if perhaps only temporary) in less than another day.
Mike and I are still working out the details of possibly another fix that will improve the reliability of the machine, by changing the diodes out for better, (non-parallel) ones. But in the meantime, I am up an running again.
So, if your machine breaks, and you have a little bit of electronics knowledge, you may be able to fix it yourself! You might not need to be as dependent on the warranty repair department as you thought, after all. ;)
If there is interest, I can post some tips on "how to" perform some limited diagnosis with a multimeter, how to desolder components from circuit boards, how to make a good thermal connection to a heat sink, how to remove this board from a Super200P. Other good things to do while you are deep inside your machine. (Just let me know.)
Anyway, it's good to have my machine up and running again! I hope this info is useful to you all.
