Oxy/Ac weld aluminum for a horse stand
I need to make a stand for my wife's horse to stand on with her front legs for a trick show, something similar to the stands you see in a circus that the animals get up on. So it needs to be strong, but weight's an issue since we have to move it around. Been using something made out of wood, but it weighs more than the horse.
I'm a pretty good gas welder but have only welded steel, and have brazed a bit. What's involved butt welding square aluminum tube, probably 1-1/2" square, maybe 1/8" wall or so? The stand is 3' feet square, 2' off the ground. I assume the aluminum alloy will determine the rod to use? I'm not sure where to buy this material. I buy steel from a local supplier, they don't carry aluminum. My friend's an engineer, he'll check the structural design once I figure out if I can do this and what material to use.
thanks
