Project #2 Dyethor Drain bowl for machine.
Hello,
Today I'm going to make a drain bowl for one of our machines. It sets on top of our machine and collects the gasoline and drains it through a hose into a storage tank.
Metal required is;
1 10" piece of 6" sch 40 steel pipe cut square on both ends.
1 6" round 1/4" plate steel.
10 pieces of 1" angle stock 3/16" thick cut to 1" long pieces.
1 1"npt coupler.
I use a automatic band saw to cut the 6"pipe and the angle iron. A plasma cutter to make cutouts on the pipe. A drill press to drill the holes. A mig welder to weld it all together.
This first picture is of the Blank round plate. I need to find the center and locate where the other holes will go.
http://www.everlastgenerators.com/fo...6&d=1329414594
To find the center-line I use a compass and make a few arc's the distance of the compass doesn't really matter. You just put the pivot end on the edge of the circle.
http://www.everlastgenerators.com/fo...7&d=1329414605
The next arc you make by putting the pivot end at where the first arc ends. and make another arc.
http://www.everlastgenerators.com/fo...8&d=1329414618
You only need to make one last arc. using the same method.
http://www.everlastgenerators.com/fo...9&d=1329414629
Next you get a ruler and make a straight line based on where the arches intersect. This will always be the exact center line if done properly.
http://www.everlastgenerators.com/fo...0&d=1329414640
Now using a ruler you can measure the distance of the line and divide it by 2 to fint the exact center of the circle.
http://www.everlastgenerators.com/fo...1&d=1329414652
Based off of the dimensions in the technical drawing of the cylinder. I use the following formulas to find the distances of where I need to locate the holes.
http://www.everlastgenerators.com/fo...5&d=1329414702
Then I get a ruler and measure from the center mark of the circle on the straight line the distances to where the holes will be located. Once I have those marked. then I use measurements for side A and B and mark on a square. Line it up find and mark the top hole location. then flip it over to find the bottom hole location. The center punch is pointing at one of those locations.
http://www.everlastgenerators.com/fo...2&d=1329414664
Here is the plate with all the holes drilled. The center one is 1.5" diameter and the four other ones are 3/8.
http://www.everlastgenerators.com/fo...3&d=1329414677
This is how the place mounts.
http://www.everlastgenerators.com/fo...4&d=1329414690
