Hello all,
I want to relate a problem I had with my PowerCool W300, in hopes that it will save someone else a big headache.
I was welding the other day for about 10 minutes at 170 amps AC with my WP20 torch, when I happened to look at the sleeve containing my cables and noticed that the power cable melted through the water jacket. I suspected that the pump was not doing its job, even though the water reservoir would get warm when welding (suggesting there was water flow through the torch).
I emailed tech support yesterday (with my phone # included) at 11:45 central standard time to ask for help as not to void my warranty. No response as of this morning. I decided to take matters into my own hands, and found the flow rate of water out was about 1 drop/ second. Not much flow happening there. I investigated further to find that there is a silicon rubber grommet in the reduction connector to the water out, that was restricting flow. I trimmed the inside diameter of this grommet with an exacto knife and reassembled. Water now gushed out of the connection.
What a shame I had to burn up a perfectly good WP20 torch to find I had a problem with restricted flow from the water cooler. :(
By the way, still no response from tech support.
The PowerCool W300, PT 250EX, WP20 torch, and cart were all purchased in late December 2011.
