Project #5 Dyethor trade show display
Hello,
This is a trade show display I made for our sales guys. It consists of a heavy base that can be picked up with a forklift from any side via built in forklift fork tubes. An arm and tray that holds a demo gas tank. A machine we call a rhino drain. This project took 4 weeks to complete.
The base is made of a frame that uses 4"x6"x 1/4 tubing for the sides. 4"x 8" x 1/4" tubing for the forklift tubes. A 4'x8' x1/4 sheet steel for the deck surface. A 5"x5" x1/4" for the machine mount post. Some 1/2 plate cut to various bracing shapes.
Here is the frame for the base. this 2/3 welded. I used a Mig machine for all the welding.
http://www.everlastgenerators.com/fo...3&d=1329240244
This is the first pass done with a tig maching. This part a corner on the tank holding arm.
http://www.everlastgenerators.com/fo...3&d=1329238713
This is the top part of the tank holding arm.
http://www.everlastgenerators.com/fo...5&d=1329238720
Another shot of the holding arm.
http://www.everlastgenerators.com/fo...6&d=1329238722
This is the arm mounted onto the base. It is hinged on one side of the base plate and has the two bolts to bolt it into place. I made it hinged to make it mo0re compact for shipping.
http://www.everlastgenerators.com/fo...9&d=1329238748
