New Power Master 205
Just tried out the PowerMaster 205, Plasma is pretty good, stick welding good also, can't seem to get used to the Torch for Tig it is just way too big. Not sure what all the knobs are for yet, 2T-4T and the arc force. Just not used to these functions but impressive unit for the money!
Welcome,
You might want to check out Jody's site weldingtipsandtricks.com and the videos he has done with the everlast welder's here: http://www.weldingtipsandtricks.com/...ent-pulse.html
Arc force increases your amperage to compensate for your voltage and overall wattage loss when you push in with stick. Its a great feature add for an inverter as it helps prevent the electrode from sticking and increases arc stability.
