Went to my storage area to get and use my PU205P and it appears someone has walked off TIG torch. Does anyone have one for sale shipped to 44077? Thanks,
Ken
Ken
Hey, Ken, haven't heard from you in a while! Welcome back.
Sorry to hear you had a theft- if all they got was the torch, then it sounds like you got off light.
Ken sorry to hear about this, nothing worse then a thief. I have a 26 torch setup that came with my PP205 that I'll part with. It was only used enough to make sure it works. It is a rigid 26 body with a denom zipper cover and torch switch. I'll set it up with a new 3/32 setup with a 6 cup, a ceriated tungsten ground but not used and a long and short back cap. Hows 75 bucks priority shipped to you.
Thanks and I appreciate the offer. One of my coworkers says he has an old one that he will give me if he can find it. However, if it needs a bunch of modifications to make it work, it won't be worth the effort so I will get back with you. Yours should just plug right into my PU205P, correct?
ken,
Just verify which pin diameter you have on the DINSE. I believe they could have changed. I am not in the main office so I dont get to see them often these days. Older units had 3/8". Newer unit could have 1/2"...though I am not 100% certain on that model.
Not sure what size your machine accepts but my Dinse is the 1/2" 35-70 and the 7 pin connector is 15.5mm.
My welder has a 3/8" Dinse connector so it may be better for me to just order through Everlast. Thanks Mark and everyone.
Ken
