http://www.amazon.com/dp/B0081BF3XE/...I2RRD3D1P5U4RT
Hey Guys, I 'm looking at buying this Plasma Cutter off Amazon.
Do you know what torch is on it?
I'm looking for a AG 60 or SG 55, because I have a bucket load of tips for those torches.
John~
John~
That's what it has.
great, I like these torches because the torch tips are only two(2) pieces!!!!!!
Not a million swirl rings and shields etc.....
and the tps are easy to come buy.
~John
Yes, but this is a entry level MOSFET machine. Not as rugged, and not designed for heavy or every day use.
Its better than most any clone mosfet unit...but it is NOT a unit for you if you have to ask. ;)
and the fact you said you had tons of consumables to use for one.
This is the Plasma cutter I want to buy.
What is the difference and limitations?
I don't know what else I can say that I haven't already said.. Please research MOSFET Plasma cutters. I've already said this unit is a MOSFET which are well known for the lack of durabilty compared to IGBT and I don't recommend it for you. Limitations: Light, occasional homeowner use only.
Spend a few more dollars and get the PP50 http://www.amazon.com/Everlast-Power...PowerPlasma+50
you'll be happy.
If you have a welding shop, I would recommend looking at the power plasma 50.
Heavier duty for everyday use, also uses S45 consumables you can find all over. Even Harbor Freight by me carries them. Up to 1 inch cut. Nice machine, great for CNC use as well. Yes it cost more, but it will be there for you everyday. I have, over the years, used the PP50, 60, 70 and 80. Currently I have a 80 and 50. You will not be disappointed by the PP50, light weight too.
amazon has the older model pp50 and pp60 plasma cutters that are last years model that you could get . I believe they use the AG60 consumables because they have the older torch. The new one comes with the s-75 torch. Mark or one of the other ever last support team should be able to confirm what torch they come with.
