Remote options for powerarc 280sth
I've got 280 sth and want use an amperage control remote with it. At work we use Millers with thumbwheel remote that can started argon flow and adjust amps.
Searching this forum for amperage controls only seems to show results for the Tig welders, not the stick welders that can Tig. And the torch Everlast sells with amperage control does not state which welders it works with, but a forum post I found said it does not work with the digital Tig machines.
I'm able to solder and rewiring a remote or changing out resistors would not be an issue if somebody can confirm there is a way to get an amperage control to work with my machine
