5 Attachment(s)
First project with my new Mig.
This is my welding table project and the first time with the I-200
Used 1.5 x 1.5 x .250 angle for the frame and a combination of 6x1/2 and 8x 1/2 on the top. I butted the 8 inch flats and left 1.5 in between the 6 inch slats.
5 inch casters are from Caster city two fixed and two total lock swivel
I am going to bolt the slats from the bottom so I can remove them for room or replacement if they warp too much
3 Attachment(s)
clamp system for table slats
Here are a few shots of what I came up with to clamp the slats to the table.
Pic #1 is the hardware and parts I fabricated
Pic #2 is how they go together
Pic #3 is the clamp in place holding the slat to the table.
I machined blind holed .400 deep in the .500 slats then drilled and bottom tapped then to take 3/8 x 16 threaded Rod cut to 1 3/4 inches, I used locktite 262 and tightened them into the slats The aluminum spacer is 1/4 inch thick to match the table frame and the clamp is made from scrap I cut up to 2.5 x 1inch plates. It seems to work well so as soon as I strip off the powder coat from the frame top (which I have to do if I want continuity of ground to the slats) I will mount the slats
6 Attachment(s)
More additions to the welding table.
Well I am starting to understand my new Mig and my welds are finally starting to improve. There is a close up of them in the pictures so please feel free to let me know what I need to improve on The welds were on 1/4 plate to 1/4 2x2 sq. tube Settings were 21 V and 185 amp with .035 wire and 75-25 mix.
Pic # 1 Is the receiver tube and vice plate I cut with my 50A plasma just welded up.
Pic # 2 Is a close up of the welds on one side of the plate. Please fell free to critique them settings are listed above.
Pic 3 # Is a shot of the clamp hanger bar I put on the other day.
Pic # 4 A close up of the receiver tube welded to the table frame and the lock bolt setup, I will be adding a length of rod the the bolt head so I dont need to get a wrench to make changes.
Pic 5 A another view of the table
Pic # 6 Vice mounted and sitting in its Place of Honor in the shop.
I still need to figure out a way to attach a cutting table with catch bin for the sparks and drops I will be making I will either hinge it or since I mounted a second receiver tube I may make a slide in arrangement. any in put on that would be great especially pictures. :)
Hope you enjoy
Ray
3 Attachment(s)
Cutting Grid insert pictures
Here are pictures of the cutting grid I'm making. I will be adding a hopper under the grid to contain the slag and sparks.
