Bill,
The pedal is the same for the LX and EX. Can you call tech support and get Mark or I and we can answer any questions you might have. We do have a new low profile foot pedal.
Bill,
D'oh! That's a surprise! It sure looks exactly like the connector on my 3 year old Everlast Super200P... but then again I haven't actually bought one to test fit like you did. :confused:
Question for everlast: Did everlast use the same 7 pin footpedal connector across all their machines, past and present?
The newer machines have a larger 7 pin connector. The pins are larger too.
Thanks for shedding light on this, Mike! I'll bet that connector I posted the link to is still probably the correct part for my "oldschool" Everlast machine then.
Edit: Ray, want to sell me your connectors? (I probably have more use for them than you do. ;) :lol: )
We are still working on getting them here. In the meantime the older ones have be upgraded a little for better operation.
I got the connectors from that exact post 2 for 3, if you would like them i'll send them to you for the cost of the postage.
Just PM me.
Ray
P.S. I have a guy at Greybar trying to find the correct ones now. (I gave him a sample, but there are no part numbers on the original connectors) I'll share part numbers for the replacements if he is successful.
Jake,
I was cleaning up today and found a smaller pin size 7 pin connector (Super series). PM me an address and I will send it to you if you need it.
For those of you that need information on connectors, like how to determine the size and type etc, check out this website
http://www.weipuconnector.com/newpro8.htm
The WS16 size in particular.
The way to size your connector is to measure the outside ring that screws on, and subtract about 5 -6mm for example a WS 16 will measure about 21-22 on the ring and so forth.
Which base model for the pedal on their web site would it be? Didn't find a search box to put the model number Steve provided in...
Thanks!
Mark or Mike, any luck on pictures of the new low profile pedal yet?
Here ya go...
Attachment 3131
We've had the new low profile for some time now, at least since March.
Zoama, the one above, is from SCC controls, not us.
I took the picture from everlast's ebay ad for everlast welders... http://cgi.ebay.com/New-Foot-Control...item3369c0fb37
Mark if that's not it, then can you post a picture of the new model? thanks.
I'll have to find the post, but Duncan has posted it here on the site already. You can either search through them or I'll try to find the post a little later, when I get caught up.
