Originally Posted by
ogorir
I believe mark's right here.
if there's a fault in the machine that shorts one of the welding leads to the case, the internal breaker OR your wall breaker will trip. the only situation that I can see that would make the table hot is if the hot lead shorted to the case (giving it a ground reference) and the work lead shorted to mains voltage, or somewhere on the high-side of the inverter. I don't actually think that's remotely possible.
the only issue i see with grounding the table anyway is contaminating your building's ground. on the other hand, if you were to run a dedicated ground to a separate grounding rod outside, it would actually probably help your noise situation (at least with HF tig)
anyway, the real point here is if there was even a small chance of the work leads being 'hot,'* the machines wouldn'tve been approved for sale in this country. UL rules are pretty crazy regarding this kind of stuff.
*hot is a relative term. the OCV on a stick welder will shock the crap out of you, if you're stupid, same with a tig. if you were to stab someone in the chest with a stick electrode with the welder on, it would kill them pretty easily. the real issue is keeping mains AC off of your work outputs, as mains AC is significantly more dangerous. (higher voltage and as far as your body is concerned, unlimited amperage)
