Results 1 to 17 of 17
Thread: Water vs Plasma
    Default Water vs Plasma
    what damage will water or moisture in the air used for plasma cutting do? I sometimes use more electrodes than other times and thought it may be moisture.
    J. D.
    Hobbyist
    Everlast Owner
    It will eat up you consumables and cause poor results in cutting. Yes, it probably is the moisture.
    yep it's moisture fore sure. one of my old shops where i worked had a climate control unit and humidity control was a big factor . you may also want to make sure you have a really good moisture trap and mount it as close to your cutter as possible, preferably on your cart before the unit.
    Don
    MTS 200 workhorse
    PowerTig 250EX <---sweet
    80 amp HF inverter arc welder
    Lincoln Buzzbox
    Rotobrute AC-35 Mag Drill
    Milwaukee mag drill
    Fullerton, Ca
    USA
    I installed a small, inline "dessicant" filter in my air line on the back of the unit where the air goes in for plasma usage. Combined with ditching the shade 9 arc welding helmet lens (and using a more appropriate for plasma, shade 5) so I could actually see how far I'm holding the torch away from the surface, I immediately got much better plasma cutting results and longer consumable life.
    Apache Junction, Az
    I use 2, one cheap HF right at the compressor and the MotorGard on the plasma. Motorgard has the highest level of protection and the HF works as an inexpensive prefilter. Hopefully, the prefilter will extend the life of the expensive Motorgard unit.
    Hobart Handler 175
    Hobart Iron Man 230 with spool gun
    Thermal Dynamics Cutmaster 52
    Makita Cold Cut Saw
    Possible future addition:
    Lincoln Invertec V311
    or Miller Dynasty 350
    or ???
    Feb 2011
    Mountain Home Arkansas
    Yes moisture is a large culprit in the early failure of plasma cutter consumables; you must have clean air as well. This includes rust and other particulate contamination from the lines and from the compressor. Older and wore compressors can also introduce oil mist to the air lines. I have made a air system that works very well, in condensing the moisture out of my system. I will take pics and post a description of it soon. But I still use a particulate filter and a desiccant filter that I built, in which I can remove the desiccant media and bake it to regenerate it. I will be listing and adding pics to all of my setup soon.
    P.S. I did find this as a cheap way out for now.
    http://www.usaweld.com/Super-Dry-for...rs-p/25300.htm
    SHOP SETUP
    Esab Migmaster 250
    Everlast PowerPlasma 50
    Miller Dynasty 200 DX TIG
    CNC Express SQ Mill
    CNC Lathe 1236
    Plate Shear 12"
    12" Slip Roll
    4 Ton Notcher
    4 Ton Hand Punch
    52" 18 Gauge Foot Shear
    48" Pan & Box Brake
    Spot Welder
    50" Slip Roll
    English Wheel
    Bead Roller
    Planishing Hammer
    60" Hand Brake
    7" x 12" Bandsaw
    Hand Tools
    Shop (TOO SMALL !!!!! )
    I don't owe anyone a dime, but I get paid to lay them down
    mission viejo CA
    also it helps to drain the water from your compressor tank often
    Lincoln precision tig 275
    Miller Syncrowave 350 Tig
    Miller 250 Mig
    old miller 200 Mig
    HF 151 Mig
    HF 100 FC
    Victor Journeyman Oxy/Ace set up
    Bunch of tools of the trade to much to list
    Apr 2011
    Sasktachewan, Canada
    I had considered the desiccant filter units but found their rate of flow too slow/restricted for my uses. My solution was to run 3/4" copper from the compressor up (always use a slight incline) to a large plastic culvert I converted to a five foot "water tower" by having a plastic bottom welded on after I had run my copper lines and drain run down into it. The bottom horizontal run is an 1.25 copper to expand the air and drop the moisture out. It is always full of water and stays chilled. For painting I will add snow or ice. Out the top and a sloped run to my filter and regulator. Straight run to a T trap and then more sloped runs head out to the different access points around the shop. All runs end with water/contamination traps as well. (all traps of course have drains) All air couplers are plumbed out of the top of the feed lines so any contaminates should pass by and not get fed into the equipment but should flow to the traps.
    I don't have a plasma at this point. But I do use this setup for my sandblasting. I haven't conducted any humidity tests but my medium stays very dry and reusable.
    Attitude Determines Altitude
    Do you have a picture ?
    Thanks,
    rivets
    thanks for the link robert i ordered a couple just incase
    everlast i-mig 200
    96 gmc extended cab truck 350 rwhp daily driven for 289,000 miles
    88 jeep cherokee custom built by me for me for well everything.someday it'll be finished
    4.6L stroker,dana 44 front, 14 bolt rear, 35"xterrains,soon to come 231/205 doubler
    Apr 2011
    This is my compressor set up. As noted earlier all lines run on a slope towards a drain. One pictures shows the feed out the top of the line to reduce moisture or contamination following. The high pressure short hose is to isolate any vibration. Before everyone gets all over me, I know there is no guard. Never was one, it is one of the reasons I am looking at getting a TIG. Until my guard is in place the compressor is run, with the door locked, then shut off when full. A royal pain, but this has resulted in no injuries or near misses.
    Attachment 1658Attachment 1657
    Moisture sucks, for plasma cutting or welding. It will lead to more consumables being used and it can damage your machine. Filter, filter, and filter. Just watch out for flow restriction. As far as using a desiccant filter, you can ruin a small filter within minutes depending on pressure and moisture content in the air. Not to mention if the desiccant gets into your machine it makes for a really, really bad day.
    This thread offers for info on filters.
    http://www.everlastgenerators.com/fo...siccant+filter
    I switched to the HF mini inline desiccant filters based on price and cut quality (I still have a larger dryer/filter at the compressor). I put a regulator right before the filter, right at the back of the plasma cutter, and note 90 PSI rating). I was quite pleased when they worked as well as anything similar I tried. I caught them on-sale once for $4.99 each and stocked up (normally $7.99). The brand name and HF have only on difference I can see, but they work quite well (brand name is better built of course).
    http://www.harborfreight.com/inline-...ter-94733.html
    Here is an easy way to maintain the right distance from the work for straight cuts.
    Remove the wire standoff and use a piece of 1/4" aluminum as a guide. It fits into the notch formed by the cup and tip for the style of torch shown in the clip. This gives 1/16" gap between the work and the tip, perfect for a clean cut. A bigger gap makes for a sloppy cut, any closer is hard on the tip.
    http://www.youtube.com/watch?v=N9HSk...eature=related
    Glen
    Everlast PP256
    Everlast Imig 200
    Everlast Power Ultra 205
    P&H 400 amp A.C.
    well i've been using 1 of the filters robert provided a link for and i've noticed a huge increase in cut quality and i don't seem to be having as many problems with the torch cutting out in the middle of a cut. i was actually about to send the unit back for repair because of the hf flickering out during cutting. i've even been able to turn my amperage way down. now if i could just figure out why the tig was giving me issues but maybe that's from water in the line also. anyways that's gonna have to wait till i can get an argon bottle
    wish the filters would last longer but i guess living on the texas coast and less then a mile from the bay has it's draw backs
    everlast i-mig 200
    check out this set up on this site.....http://www.dune-buggy.com/webs/Off-R...ompressor.html
    I am in the process of making the very same set up for my compressor. Best to get the water out before it gets to the tank. Cooling the air down and removing the water before it gets to the tank is the best set up IMHO. Saves the tank from getting rusty and drains the water away before it does its damage.
    I'm glad you posted that....I've been thinking of doing the exact same thing but have yet to source a condenser. I started looking around and it looks like a heater core may be the way to go. Cheap and can handle 175 PSI
  1. TIG Water cooler
    Last Post: 06-24-2015, 01:53 AM
  2. Need to plasma cut some circles/holes soon. Cheap magnetic circle plasma jig.
    By everlastsupport in forum Personal Projects (no welder required)
    Last Post: 05-15-2012, 03:06 AM
  3. New Water Heater
    By Powertig in forum Personal Projects (no welder required)
    Last Post: 05-03-2012, 03:57 AM
  4. DIY Water Cooler
    Last Post: 06-10-2011, 02:22 AM
  5. Water Coolers
    By Richard in forum General Welder Questions
    Last Post: 04-15-2011, 12:07 AM
