Results 1 to 14 of 14
Thread: PowerTig 250ex not working...
chris.hindley PowerTig 250ex not working... 10-06-2010, 11:10 PM
cmd so have you actually verified... 10-07-2010, 12:36 AM
performance Its likely one leg of power... 10-07-2010, 02:23 AM
geezer Why do I get the feeling that... 10-07-2010, 03:46 AM
chris.hindley So am I supposed to just tape... 10-12-2010, 03:31 AM
performance Yes, it should be taped off. ... 10-12-2010, 03:40 AM
Rugar Oh, say it ain't so! I'm... 10-07-2010, 04:05 AM
nanaf I am pretty sure that tiny... 10-07-2010, 04:41 AM
performance Geezer, Yes, that too is a... 10-07-2010, 06:01 PM
chris.hindley Oh wow I know exactly why I... 03-30-2011, 12:22 AM
performance Download the manual on line. ... 03-30-2011, 01:39 AM
everlastsupport You can still use that plug,... 03-30-2011, 01:48 PM
  1. Default PowerTig 250ex not working...
    I bought my powertig 250ex about 5 or 6 months ago and it didn't come with a plug end so I went out and bought a NEMA 14-50P to go into a hottub receptacle. The receptacle says 230V but when i try to weld with it I only get a very very tiny spark when i touch the tungsten directly to the aluminum. I also don't hear the high freq. kick in until about 15 seconds after pushing the pedal down fully. There's also no gas flowing whatsoever. I have no idea why these things aren't working. Any recommendations would be greatly appreciated.
    so have you actually verified the voltage at your outlet you are plugging into? has this welder ever worked? or has it been sitting in the box for 6 months?
    Its likely one leg of power isn't working. Check your connections. This symptom has usually a poor or weak input at the root cause.
    Why do I get the feeling that the red 3 phase wire is hooked up in that plug somehow??
    So am I supposed to just tape off the red wire? And what about the gas flow? (btw I'm an A level welder so I know how to set up a machine and the regulator/flowmeter I've just never had to set up the electrical portion)
    Yes, it should be taped off. The flow is in lpm, about half of what cfh is.
    So I finally got an electrician to wire up a new 240v receptacle (I needed to get a new one anyways since I didn't want to keep unplugging the hot tub) and it didn't fix the problem with the machine still! Neither the electrician or I understand why I'm supposed to tape off the red wire. Isn't the red wire a hot wire? Wouldn't taping it off make it 110v instead of 220v? This is my understanding of the wires: Red and black=hot, green=ground, white=neutral, Is this correct? I also found that either having the red wire connected or not the amperage was only going up to 195 on the screen and once I pressed the trigger/pedal it would drop down to 66 amps. It's really starting to bug me cause I want to start making some money with it and I haven't been able to do anything with it since I got it (about a year ago). Any help would be greatly appreciated!
    Quote Originally Posted by cmd View Post
    I'm waiting for mine to get here. It will be fired up before the UPS driver even has a chance to get out of the neighborhood!
    Gerald
    Millermatic 251
    Spectrum 300 Plasma
    Everlast PowerTig 250EX
    Everlast PowerCool W300
    Harris / Victor OA
    ProTools Air/Hydraulic Bender
    I am pretty sure that tiny spark you are seeing is the high frequency itself. Are you sure you have the torch plugged into the correct port? I am sure this is obvious, but I still feel I should say it. Is the argon actually opened up? You should be sure you have the knobs turned correctly, if you are using the flow meter that came with it, there is a second knob on it that you need to mess with, there are two ways to test the gas flow. First, set the post flow to at least 5 seconds, then tap the foot pedal or the button on the torch briefly, then bring the nozzle towards your skin. If it is flowing, you will feel it for sure. The nozzle included has some sort of floating ball thing, when you are feeling for the gas flow, look for the ball to raise.
    Geezer,
    Yes, that too is a common cause. It wouldn't be the first time.
    Oh wow I know exactly why I did it wrong now. I read the manual I got with my machine and it just says "nema 50 amp". So I went out and bought one to fit where I was going to plug it in (a hot tub receptacle) then I went off of what it says on the nema 14-50 (it actually says right on the plug that white is neutral). Man I'm dumb hopefully I didn't mess up the machine. This is why I'm a welder not an electrician. Thanks for the help! I'll try it some time this week (it's not at my house) and let you know how it goes.
    Download the manual on line. Throw the pamphlet away.
    Quote Originally Posted by chris.hindley View Post
    You can still use that plug, just no wire on the neutral pin/prong. Put the black and white on the two hot pins/prong and green on the ground and you will be fine with the plug. I use 4 prong twist locks all the time for generators, we just have no neutral.
  1. 250ex Arc Force not working?
    By Monty in forum Stick Welding (SMAW)
    Last Post: 08-21-2016, 12:58 AM
  2. HF starts quit working - PowerTIG 200DX
    By Timebandit in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-04-2014, 02:04 PM
  3. PowerTig 225LX Foot Pedal stopped working, How to Ohm Test?
    Last Post: 12-18-2012, 06:40 AM
  4. PowerTig 250ex
    By going360 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-17-2010, 11:01 PM
