Results 1 to 20 of 21
Thread: New powerplasma 50 owner
    Default New powerplasma 50 owner
    Hey guys I just ordered a powerplasma 50 and kind of wanted to know how everyone liked theirs. Is there anything specific I should look for before start up? What kind of water traps are you guys using? Thanks in advance. Tim
    Quote Originally Posted by powercat View Post
    I wrote a review of the PP70 on this site. The machines are probably not that different.
    Watch for interior air line leaks. I replaced mine with nylon truck air brake lines and compression fittings. But if you don't hear any hissing leave well enough alone.
    I'm using the Harbor Freight 3 foot long desiccant air dryer for around $40. The smaller inline ones seem to plug up the air flow. The shop's main compressor has a water trap and one should be included with your PP50 that attaches on the back if it is like the PP70. Others may know more about the PP50.
    to answer some questions from your PM: consumables; the consumables that came with the torch cut very good but did not last that great. I got trafimet brand from fastenal, they seem to last better but I feel they won't cut as thick. I need to take some measurements to compare the orifice size. I haven't tried the everlast replacement consumables.
    The replacement consumables will outcut/last the trafimet on the newer ones.
    Quote Originally Posted by cmd View Post
    The consumables that are supplied with your Torch areTrafimet Consumables.
    You can verify this by lookig for the T in a circle on your tips.
    We do find our house Brand Consumables to be better than the Trafimet .
    Cheers
    EVERLAST CANADA
    www.everlastwelders.ca
    www.titanwinches.com
    905 637 1637
    Default pp 50
    fastenal has consumables? Thats great, I have a fastenal store right down the road. It's good to know that I'm limited to the internet for consumables. I knew harbor freight carries them but thats a 45 minute drive. Thanks for the info guys.
    Not an official company endorsement of these brands mind you....but...
    There are a few other places you might be able to get them off the shelf for the s-45 torch. I think it might be a special order from Fastenal, at least the one here.
    Hobart distributors. The new large hobart unit uses an s-45.
    Northern Tools
    Tractor Supply (hobart)
    Tool Trucks (some of them sold equipment with s-45)
    Harbor Freight
    Anyone care to add to the list?
    Cheers
    well indeed they are. I never looked to see until now. after some checking, you can get these consumables in 0.6mm or i assume 0.8 mm orifice. the ones fastenal got me was the smaller. the ones that were included are labeled 0.9 mm on their side
    Default pp 50
    If Hobart's plasma uses the s45 torch then the Attwoods here should have consumables. I will have to check after the pp 50 gets here.
    I dont have any plasma cutter at this time. I was just kinda curious how clean they cut? they look like a sawed edge or what. A lot of things I could use it for. Thanks
    Frank
    I have a 250 EX welder and several other machines and equipment to allow for small scale manufacturing and prototyping of inventions
    I am located in Oregon about 20 minutes west of Portland
    Jul 2010
    SW Ontario Canada
    The quality of the cut will depend on a number of factors. Material type ,thickness , machine set up and lastly your cutting ability. I can cut most material with my PP50 and have a very smooth edge with little to no dross. Plasma is capabale of amazing cut quality especially if used with a cnc table.
    Quote Originally Posted by Nikola Tesla View Post
    Farmer pretty much covered it all. The "cutting ability" helps the most, lots of practice. Fast cuts will leave little or no dross. Good steady hand is also key. You will be amazed at how good they cut when done right.
    I used mine extensively today. If you use the roller guide and a straight edge it almost looks like you cut it with a saw. Very cool!
    Tim
    Powerplasma 50
    Miller 211 autoset
    Northern industrial dry cut
    Hobart 11 KW gen welder
    AO torch
    im still waiting to place my order for a plasma cutter. at least i did get my powe arc 160
    Aaron
    btw anybody use their PP50 on 1" or thicker steel yet?
    Aaron
    Quote Originally Posted by yotarover View Post
    Duncan, Mark and I have all cut 1" with the Power Plasma 50.
    Yota,
    While it will do 1" it is not recommended for continuous use at that thickness. I hope that is not what you were intending. If it is then you need an 80 amp.
    And old rule of thumb for plasma cutting. If it's a 50 amp unit (or at 50 amps), it will cut .50 inch. If a 75 amp, it will do .75 (3/4) inch. Put a decimal point in front of the amps. Though the answer to you question is still yes, it can cut up to 1 inch but you will be pushing the unit.
    Feb 2011
    Mountain Home Arkansas
    Yes I have cut 1” with my PP50 but only 30 or 35 pieces of round stock. I needed to get them close to size to put them in the lathe, and the band saw blade broke. So like all people with the good scene, God gave a monkey. I broke out the new PP50 and went to it, while the cuts were not clean they were much better than I expected. This machine for me excels in the ½” and under, cuts 5/8” to clean up spec and good severance at 1”. I mostly cut 3/8”, ½” and sheet gauge material and it does a great job for that.
    And yes I had new band saw blades but you know how it is to have a new toy to put through the paces.
    SHOP SETUP
    Esab Migmaster 250
    Everlast PowerPlasma 50
    Miller Dynasty 200 DX TIG
    CNC Express SQ Mill
    CNC Lathe 1236
    Plate Shear 12"
    12" Slip Roll
    4 Ton Notcher
    4 Ton Hand Punch
    52" 18 Gauge Foot Shear
    48" Pan & Box Brake
    Spot Welder
    50" Slip Roll
    English Wheel
    Bead Roller
    Planishing Hammer
    60" Hand Brake
    7" x 12" Bandsaw
    Hand Tools
    Shop (TOO SMALL !!!!! )
    I don't owe anyone a dime, but I get paid to lay them down
    is that same for any type of metal?
    sold my miller mig
    got a PT250EX
    saving up for a plasma cutter
  1. Powerplasma 50 pac
    By Steveg63 in forum Pre-sales, Sales and Shipping questions
    Last Post: 06-13-2014, 02:34 PM
  2. PowerPlasma 50 vs PowerPlasma 80
    By FordSloman in forum Everlast Plasma Cutters (PAC)
    Last Post: 03-26-2012, 02:20 PM
  3. Powerplasma 50
    By trickbiker in forum Customer Testimonials
    Last Post: 10-01-2011, 11:50 PM
  4. PowerPlasma 50
    By AMDninjaboy in forum Everlast Plasma Cutters (PAC)
    Last Post: 11-22-2010, 01:25 PM
  5. Powerplasma 70
    By jfley in forum Everlast Plasma Cutters (PAC)
    Last Post: 02-23-2010, 05:59 PM
