Originally Posted by
A/C Guy
2. They decide that if 50 amps (in your example) is good, then 70 amps is better. So they install #4 wire and a jumbo breaker to match. The problem that occurs is that if there is a failure in the machine, the jumbo breaker does not trip. That allows more serious damage to the machine. I see this every month in my line of work. Too large of a fuse or breaker and a $400 repair just turned into a $1400 repair. The manufacturer's engineers determined that a certain breaker is correct. That is why they list a MAX fuse / breaker size on the equipment. When something fails, the the internal components are no longer protected by the 50 amp breaker. More components fail until the 70 amp breaker trips. Sometimes, the entire unit will catch fire before the oversized breaker will trip. Now the repair bill just got very expensive.
Sorry, but this statement simply isn't true.
Breakers/fuses are sized to protect the circuit run (ie-correct wire gauge size), not the appliance in use.
If the above statement were correct, you should never plug your television/stereo/phone charger/etc.. into that 20amp receptacle in your wall as none of these items are 'load protected' by a 20amp breaker.
-at the job-
Miller Dynasty 200DX
Miller Syncrowave 350
MillerMatic 250 (several)
Millermatic 350
Miller Bobcat 250 (Service Truck)
Lincoln AC225 (many)
Miller Spectrum 625 Plasma (several)
-At Home-
Everlast PP256
Longevity 256PI
"Slow is smooth, smooth is fast.."
