Results 1 to 2 of 2
Thread: dinse adapter for 210ext
  1. Default dinse adapter for 210ext
    is the CK-SL2-35-LG the proper adapter to use a ck flexlock torch on the 210ext ? the dinse on the torch that came with the welder has a shorter pin in front of the lock tab than what is on my lincoln torch.
ID:	8402   Click image for larger version.
    Most of the time they will work. The one on the 210 ext is actually a 35/50. The biggest difference that you need to observe is where the gas/water line is connected, because the recess on the torches we sell for the other units is a little too close to the connector and the line hits on the bezel when you try to screw it in.
  1. Adapter for weld tec
    By Steves1967 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-06-2018, 04:37 PM
  2. Radnor DA 5095 Dinse to Tweco Adapter NEW
    Last Post: 09-20-2012, 04:50 PM
  3. tig torch options and dinse connector adapter 3/8 size.
    By rab in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-12-2012, 05:16 PM
  4. I need a SMALL MALE to LARGE FEMALE DINSE adapter. Where do I GO??
    Last Post: 02-05-2012, 09:33 PM
  5. adapter for new tig torch
    Last Post: 07-02-2011, 11:34 PM
