Results 1 to 6 of 6
Thread: First welds
    Default First welds
    Here are pictures of my first Tig beads with filler rod
    I am looking for input to make me better. Please let me know what you see both bad and good (if there is good it was by accident at this point)
    Everlast 250 EX
    1.5 Lanth electrode
    er70s-2 3/ 32 filler 125 amps on 4T setting
    Mild steel 1/8 plate.
    Ray
    Pic #1
    Attachment 1502
    Pic #2
    Attachment 1503
    Pic #3
    Attachment 1504
    Pic #4
    Attachment 1505
    Pic #5
    Attachment 1506
    Everlast I mig 205
    Everlast 200 amp spool gun
    Everlast 250 ex
    H. F. 12x36 lathe
    Grizzly Mill
    10,000 lb two post lift
    Box and Pan Brake
    Bead roller
    jet 5x7 horizontal band saw
    Mitec 50 A plasma cutter.
    tool grinder
    20 ton press and press brake
    70 Chevelle convert
    what size filler rod?
    sold my miller mig
    got a PT250EX
    saving up for a plasma cutter
    added to post it is 3/32.
    Everlast I mig 205
    Everlast 250 ex
    H. F. 12x36 lathe
    Grizzly Mill
    Box and Pan Brake
    Bead roller
    tool grinder
    70 Chevelle convert
    Feb 2011
    West Palm Beach Fl.
    It looks like your starting out pretty good, then the bead gets narrow, maybe this is where you are starting the down slope try making the down slope less and staying with the same width bead by slowing down and or stopping at the end.Picture #4 looks pretty good the width is about the same through out the bead, you just got a little curvy on your path. Keep practicing and have fun with it.
    Power Tig 250 EX
    Miller 211 Mig
    Hobart Stickmate LX
    Victor Torch
    Looks like you are off to a fine start. Try to turn yourself into a machine. Meaning remain consistent with everything. Every movement you make with your torch, shows in your weld. It is hard to stay consistent all the time though.
    Again, looks like you are doing fine. You are only going to get better and better.
    Also know that if you take a break for a while (weeks at a time), when you come back, you are going to have to freshen up all over again.
    10.3 @ 134mph 1.5 60' DA 7500ft Bandimere speedway
    http://www.youtube.com/watch?v=leUB4PCv0mU
    Lincoln PT185
    1980's Miller Plasma cutter
    Everlast LX225 here and working well.
    My feedback would be:
    1. work on getting a consistent bead with, by not progressing the torch forward until the puddle has grown to your bead width "target". Keep the same width "target" throughout the weld for uniform weld bead width. You don't have to constantly stare at your puddle to do this, you can use your peripheral vision to see it as well.
    2. similarly use the height of the bead to judge when you've added enough filler rod and try to keep that consistent as well.
    3. work on running your beads in a straight line. Most weld joints are going to be in straight lines, or at least careful control over the path. I would practice running your beads parallel to one of the cut edges. Which brings up another point, make your cut edges straighter to give you a better reference while welding.
    4. to reduce oxidation of your weld joint, try using bigger coupons to conduct the heat away more quickly. Or, try running smaller weld beads (switching to a smaller filler rod if necessary) for the size coupon you are using.
    When you feel like you've gotten your fill of running beads on flat stock, next step is to join two pieces together in a butt weld configuration.
  1. My first welds with my PA 160 STH
    Last Post: 07-25-2013, 03:23 PM
  2. First TIG welds
    By 2tailfins in forum Hobyist Projects
    Last Post: 09-28-2012, 02:56 PM
  3. A few of my first welds with the I-MIG 200.....
    Last Post: 04-23-2012, 03:46 PM
  4. My Welds
    Last Post: 11-09-2011, 11:23 AM
  5. how are my welds
    Last Post: 05-20-2011, 01:46 AM
