Results 1 to 16 of 16
Thread: My Smoker
    Default My Smoker
    Well, it does not look like it, but at one time I welded for a living. Welding put me through college, and it took me a while to regain my ability to fabricate. I started off with a welder, torch, and grinder; needless to say I have purchased numerous tools because of this build. I will probably put this one on craigslist when I finish, I made a lot of mistakes that I would not make again. I'm not quite finished, and I would like to take everything I learned and re-learned and do another build. I think put all the doors on at least twice, not to mention metal warping, I could go on and on about my mistakes. I built the smoker on a Northern Tool trailer kit, I wanted a smaller cooker that would be easy to move. It's 1/8" metal inside and 12 gauge on the outside with 1-1/4 angle for the frame. I added more support and bracing on the trailer. I still have a little work left to finish.
    small hunh??? makes my bradly look small - come this fall before deer season I am planning to build a smoker/bbq Something with a firebox on the side to use for BBQ and grilling stakes and such, then a smoke chamber to do nice and low smoking in
    sold my miller mig
    got a PT250EX
    saving up for a plasma cutter
    Nice, I'm going to use a water pan to help even out the heat, and it's a little more forgiving using a water pan.
    This would make my day to see toolin down the interstate at 70mph with a nice, gray plume puffing out the stacks! Any plant to go street legal?
    Miller Dialarc 250
    ESAB Migmaster250
    Smith Heavy Duty OXY/ACETYLENE outfit
    Arcair gouging set
    The Boonies of Texas
    I have a friend that swears by dry sand in a pan to even out the heat instead of water. I still use water though.
    Thurmond
    Miller Bobcat 3 Phase,
    EVERLAST PowerUltra 205P
    HOLY CRAP that is AWESOME! Making a smoker is on my dream list of things to do whenever I have extra money.
    Everlast lx225
    Hobart Stickmate LX
    Thermal Arc 400GMS
    10"-22" Grizzly lathe
    Quote Originally Posted by Mikeymetal View Post
    Considering I drive a Scion XB 70mph is out of the question! It started life as a Northern Tool trailer kit so I do have a title. It's not as big as it looks in the pictures it's a little under 5' tall from the top of the trailer to the ground, its 24" deep, and 40" wide. It's easy to handle and move around and will not take much room under my back porch. There is enough room under the fenders to add larger tires. The only thing I am nervous about is being top heavy, I may add some flat bar under the trailer for weight.
    After building this one I would do things different if I build another smoker. I purchased a trailer at Northern tool on sale for $179.00, my next one I will look for a larger trailer on craigslist, you can find them from $200.00 on up. I would use tubing instead of angle iron (tubing was more expensive), and I would use 18g sheet metal because it will bend easier, and use insulation. with the exception of the trailer you can build on for around $200.00.
    I finally got my smoker finished, all I have left is to bolt on the tail lights. I learned a lesson, I will test fire before I paint if I ever build another smoker. I had two spots that leaked because I ground off to much metal. I have to paint the left side again. It came out pretty good, and I was very happy with the cook. It hold heat very well, I had to choke it down to get the temps down low.
    Tri-tip, I am probably the only person in Memphis that cooks Tri-Tip
    Now you did not have to show that. I will have to smoke something since you made me hungry.
    Thurmond
    Apr 2011
    Sasktachewan, Canada
    Of course you realize that if any of us see that trailer smoking down the highway we are following you home! Mmmmmmm steak.....
    Attitude Determines Altitude
    This may be the greatest thing I have ever seen. I'm hungry and jealous at the same time. If you ever got pulled over with it you could just bribe your way out with some steaks. By the time the cop got to your door he is going to be so hungry. Also if you ever hit a deer you could just cut it up right there and by the time you get home it will be getting close to cooked.
    Everlast PowerTig 250EX
    Everlast PowerCool 300
    Everlast PowerPlasma 70
    Lincoln Powermig 215
    Magnum SG Spool Gun
    Don't jump on my Gomba
    Steaks are for a "grill". This is a smoker. It is made for "Real" pieces of meat. Say 5 lb chunks and up. Usually 50 lbs at a time at least.
    Thurmond
    Quote Originally Posted by Tritium View Post
    Thurmond
    You are correct sir.
    Very nice job on that smoker Sean.
    How much did you end up with in metal cost.
    I have been smokoing for a while now but with an electric model.
    Someday I would like to build a nice wood fired one like that.
ID:	5040   Click image for larger version.
ID:	5041   Click image for larger version.
ID:	5042   Click image for larger version.
    Consistency is a good thing....unless you're consistently an idiot.
    Miller Matic 185
    Thermal Dynamics Pak Master 38xl
    Everlast 250EX
    I love smoked meat. I have a little one but that beast is just awesome.
    Magnum SG Spool Gun
    Thats one awsome smoker, that is one of the things on my list to build when my welder finaly comes in. Curently i am using a brinkman smoker/grill http://www.brinkmann.net/products/ou...tem=805-2101-W it works ok but i want to build a smoker and used the brinkman for strickly grilling.
    Everlast PowerTig 225 LX
    Miller Spectrum 375
    M-Tech Model 3 Tube Bender
    JD2 Notch Master Tube Notcher
    Light Racing Dimple Dies
  1. Revers Flow Smoker
    By Gtig in forum Welding Projects and Pictures
    Last Post: 09-07-2018, 02:50 AM
  2. SeanMurphy265 Project #4 Smoker!
    By SeanMurphy265 in forum Other Custom Fabrications
    Last Post: 01-23-2012, 12:16 PM
  3. Project #4 from DVA, Smoker (UDS) for my dad
    Last Post: 10-27-2011, 04:08 PM
  4. Insulated Smoker Project
    Last Post: 10-09-2011, 09:35 PM
