Results 1 to 11 of 11
Thread: 7 pin connector
    Default 7 pin connector
    Guys,
    I hope this will be helpful for all of you considering torch changes, and foot pedal changes.
    According to Oleg, We have just received a fairly large quantity of spare 7 pin connectors (current style).
    So anyone wanting to "amp" up their pedal or create a better functioning torch, we should be able to do it.
    We have set a modest price for the plug at $11.99 US plus shipping.
    Guess I missed this post. Just read another post in another thread that a member linked to it. I will call on Monday to order two of these. One for a pedal, and one for a torch switch.
    Is the torch switch that you sell the same one that comes on the WP20 torch that you also sell? And is the switch already wired up with a plug? Or is it just the paddle switch by itself?
    Gerald
    Millermatic 251
    Spectrum 300 Plasma
    Everlast PowerTig 250EX
    Everlast PowerCool W300
    Harris / Victor OA
    ProTools Air/Hydraulic Bender
    It is just the 7 pun connector, you will have to wire it. The switch is pin 1 and 2, just wire your new torch switch there.
    Mike I think it's two seperate questions. Is the torch switch that you sell the same one that is included when you order the 20 series torch? and if so, does it already have this 7 pin connector or does that have to be ordered seperate? I'd like to know the same things since I'll hopefully be ordering a 20 series torch here in the next few days
    http://www.ideadevgroup.com/
    Our WP20 comes with the switch in the torch and the 7 pin DIN on it. It is a complete torch for our units. Sorry, I did not understand the switch question when the topic was 7 pin connector. Do not buy the connector if you are buying the torch from us, it has one on it.
    I had one of your WP20 torchs and returned it. I know that it comes with the torch switch installed.
    You also sell a switch seperate on your site. Im wanting to know if the switch you sell is the same one thats on your WP20? And does the switch that you sell come wired up with the 7 pin connector already installed?
    Gerald
    Millermatic 251
    Spectrum 300 Plasma
    Harris / Victor OA
    Quote Originally Posted by Rugar View Post
    Still not sure I follow. Maybe Mark or Ray can help out.
    I doubt the switch is the one from the WP20, but I could be wrong. The connectors would come with no wires as would the switches. The wires would be in the sheath and need to be connected at each end.
    Can you send me a link to the part in question? I'll take a look.
    wouldn't you need to add a separate cable for the torch switch? all the tig cables I've ever seen just have a power conductor, and water lines if it's water cooled.
    I think rugar is wondering
    a) if the additional wire required to use the torch switch comes with the switch
    b) if the switch does come with a wire, does it come with a 7-pin plug on the other end
    c) if the switch that is pre-installed on the everlast WP-20 torch is the same switch you can buy separately
    it sounds like a) and b) and c) are all a no, so to do what I think rugar wants (put an everlast switch on another torch to connect to an everlast machine) he'll need to buy a 2-conductor wire to zip tie to his torch lead. shurtape cloth tape under a lead jacket would probably work too with less chance of damaging the torch lead.
    McGuire Irvine
    Crow Motor Co.
    Lincoln powermig 225 (work)
    Half way down the page.
    http://www.everlastgenerators.com/Ti...ucts.php?id=95
    Gerald
    Millermatic 251
    Spectrum 300 Plasma
    Harris / Victor OA
    Nov 2010
    Northern California
    Guys,
    Are they still available?
    We are stocking them and know some have been reordered already, though I don't think we are out.
  1. Where can I buy a 7 pin connector for my PA 160STH?
    By jchaverri in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-14-2014, 01:09 AM
  2. Euro Connector
    By millermatic in forum Everlast Plasma Cutters (PAC)
    Last Post: 10-08-2012, 05:03 PM
  3. 7 pin connector source
    By Tony_F in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 04-06-2011, 05:43 AM
  4. TIG Torch Connector Kit
    By Rugar in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 12-09-2010, 03:20 PM
  5. Ct 416 d cable connector needed
    By dchatcher in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-08-2010, 11:54 PM
Tags for this Thread
