Results 1 to 19 of 19
Thread: Mill Scale
    Default Mill Scale
    What do you use to strip the mill scale from steel before welding?
    I use the black or red open weave surfacing discs but was wondering if there is a better (read cleaner, faster) way to strip it.
    Everlast I mig 205
    Everlast 200 amp spool gun
    Everlast 250 ex
    H. F. 12x36 lathe
    Grizzly Mill
    10,000 lb two post lift
    Box and Pan Brake
    Bead roller
    jet 5x7 horizontal band saw
    Mitec 50 A plasma cutter.
    tool grinder
    20 ton press and press brake
    70 Chevelle convert
    I used to use an old 8 inch B&D body grinder, heavy ugly thing and then one day it walked out of the shop. Now I use those puny 41/2 jobs with a hard disc. They are handy but the old B&D was my favorite.
    Feb 2011
    Mountain Home Arkansas
    I use my sand blaster but all the parts I make ether get painted or powder coated. This gives me a head start on the final cleanup.
    SHOP SETUP
    Esab Migmaster 250
    Everlast PowerPlasma 50
    Miller Dynasty 200 DX TIG
    CNC Express SQ Mill
    CNC Lathe 1236
    Plate Shear 12"
    12" Slip Roll
    4 Ton Notcher
    4 Ton Hand Punch
    52" 18 Gauge Foot Shear
    48" Pan & Box Brake
    Spot Welder
    50" Slip Roll
    English Wheel
    Bead Roller
    Planishing Hammer
    60" Hand Brake
    7" x 12" Bandsaw
    Hand Tools
    Shop (TOO SMALL !!!!! )
    I don't owe anyone a dime, but I get paid to lay them down
    Unless I'm TIG welding something, I weld over it. When I do need to clean it off, I use one of those Zirconia flap wheels. They are expensive compared to a regular grinding disk, but they work very nicely.
    Everlast lx225
    Hobart Stickmate LX
    Thermal Arc 400GMS
    10"-22" Grizzly lathe
    I usually only worry about the weld area and clean that with a blending disk or hard wheel, whichever is closer. Then let the powder coater sand blast it when he does his thing.
    http://projectoldwing.com
    wruehl@hotmail.com
    Active Ironbutt Member.
    4 1/2 inch grinders with ether flap wheel or grinding disc. Which ever one I grab first. I only do the welding area thought, groove or taper as needed.
    Then when time for the prime/paint, the rest of the work happens. Normally try to pass that to someone else.
  7. Default Delegate!
    The last sentence in Mike R.'s response sounds like the ticket But really, I just started using the 4-1/2 and 7 inch flap discs. I use 40 grit or 36 if I can find them. They really get the scale cleared out better then a hard disc.
    Miller Dialarc 250
    ESAB Migmaster250
    Smith Heavy Duty OXY/ACETYLENE outfit
    Arcair gouging set
    Feb 2011
    Quote Originally Posted by wruehl View Post
    I wish I could just send it out to get a coat of powder shot on it but the only shop that does it here sucks!!!
    So I built my own booth and oven so I can do it all in house. Then when it sucks I know just who to yell at. This is why you have kids that grow up to work with dad. ( built in scape goat )
    SHOP SETUP
    Esab Migmaster 250
    CNC Express SQ Mill
    CNC Lathe 1236
    Plate Shear 12"
    12" Slip Roll
    4 Ton Notcher
    4 Ton Hand Punch
    48" Pan & Box Brake
    Spot Welder
    50" Slip Roll
    English Wheel
    Bead Roller
    Planishing Hammer
    60" Hand Brake
    7" x 12" Bandsaw
    Hand Tools
    Sait 36 grit flap disc, if it has to be more clean or smooth I'll use an 80 or 120 grit. if it has to be powder coated I blast it with my NT sand blaster, but it takes forever! looks great tho.
    what are you using for an oven? I have a little jet hot coating kit, never used it cause it seemed like a pain in the @$$. but now you got me thinking about my wifes electric oven... maybe she needs a new one, so I can have the old one....
    ...*.......-'. \..\__/
    ... /......... _/
    ...|.... /_\'
    ....\....\_/
    I also use a flap disc, but I clean both the welding and ground connection areas - without a good ground, the welds can become very inconsistant...
    __________________________
    Everlast Power I-MIG 200
    Everlast PowerUltra 205P
    Everlast SM 200-N
    Thermal Dynamics Cutmaster 42
    Quote Originally Posted by Robert s View Post
    I have three sons and they all weld, paint, etc.. Two like the powder coat, but small things (small oven). Unlike you and Ray with the big booths, I have a very large toaster oven for that stuff.
    Quote Originally Posted by kenwhite View Post
    Can't count the times I have gotten everything ready to weld, and went to hook the clamp on and mumbled to myself dang-it.
    Feb 2011
    West Palm Beach Fl.
    I use a HF pneumatic angled die grinder with the 3" cut off wheel. Its light, easy to maneuver and you can grind a small bevel with it if you like.
    Power Tig 250 EX
    Miller 211 Mig
    Hobart Stickmate LX
    Victor Torch
    Jun 2011
    flordia tampa
    Blog Entries
    1
    grind wheel hard or flap disk.I run cnc oxy table. russin metal can be hard to clean or any metal thats been on boat for long time.good to run 6010 for first bead if stick welding we call it farmers rod ,can cook out some of the crap.then use 7018
    Jun 2011
    flordia tampa
    Blog Entries
    1
    have used phosphoric acid to clean weld for painting.
    Springfield, Illinois
    Flap discs work great for me. Or if I am in a pinch a stiff wire wheel will work.
    Completed Midwest Technical Institute 40 week welding/pipefitting school!!
    Attending Lincoln Land Community College - Degree in Computer Programming
    the flap disk works good on everything except 1"x1" steel tube...not sure way but I round off the corners before I get the middle clean.
    sold my miller mig
    got a PT250EX
    saving up for a plasma cutter
    I use a flapper disk also. What is nice about them is that they seem to last way longer than a standard sanding disk. They cut much better through the mill scale and they seem to hold the ability to sand longer. More expensive than the sanding disk, but I was going through sanding disks at a fairly high rate. Now I have noticed with the flapper disks, it has cut back to very rarely having to get a new disk.
    Quote Originally Posted by Steve View Post
    the best thing about the flapper disks above and beyond the performance is that they do not add as much heat to the material. if you are working lighter gauge sheet metal you have less chance to warp it.
    Everlast Powertig 225LX
    Harbor Freight O/A rig
    60 gal air compressor
  1. Removing Mill Scale from Hot Rolled Steel?
    By Spike in forum General Welding Questions
    Last Post: 02-20-2013, 01:49 AM
  2. Your thoughts on a lathe / mill / drill combo machine
    By DaveO in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 10-14-2012, 09:20 PM
  3. For Sale: 20pc. End Mill set Brand New
    By CGCINC in forum Buy, Sale or Trade
    Last Post: 04-26-2012, 12:39 AM
  4. Project 12 from d3javoodoo ^ Jig for sm. Scale Wheel (5 spoke) ^
    Last Post: 07-27-2011, 03:46 AM
  5. HF 3 in 1 lathe mill combination units
    By Salty in forum General Welder Questions
    Last Post: 04-22-2011, 11:11 PM
