Results 21 to 40 of 43
Thread: First tig welding attempts, and wp26 torch questions
    Yep, the wheel will deposit particles into all the fine scratches it leaves behind. If the alum is very Oxidized you should use a very fine stainless brush to clean the weld area then go over that with a cleaner like we have been discussing here. I'm doing Mild steel still so the Powered wire wheel followed by a wipe of Min spirits has been working fine. By the time I'm outta bed I will have gone back a few paces in my practice I think.
    Will make some new practice Pieces out of some of that rusty old 3" .250 channel my dad got. It's very rusty so will have a lot of cleaning to do with the wire wheel or even the paddle wheel sanding discs. Still a couple weeks away I think though. I refuse to buy metal to practice on
    Don
    MTS 200 workhorse
    PowerTig 250EX <---sweet
    80 amp HF inverter arc welder
    Lincoln Buzzbox
    Rotobrute AC-35 Mag Drill
    Milwaukee mag drill
    Fullerton, Ca
    USA
    ahh ok not sure if the brush I have is fine or not, but I do know that its nice and shinny metal when I am done and if I do my part ok it weld pretty nice
    sold my miller mig
    got a PT250EX
    saving up for a plasma cutter
    Presure2;
    Post some more pics once you get some more gas and try the different cups, interested to see the difference using different cups. your definitely doing better than me I haven't even attempted alum yet with the 250ex. I did notice a few craters on some of your beads. same thing I am working on now is using the end amps feature to deposit my last drop of filler and reverse a bit as I hit the button to end the bead.
    Your probably using the foot pedal I would assume so it's maybe something you don't rely on as much as I do using pre set amperage . a little more pre flow , start/end amps feature and about 7 secs of post flow . I would post up some pics of my mild steel practice pieces but my parents are on vacation and I'm kinda layed-up in bed with no access to my camera , my mom took my camera bag with both my video and still camera in it by mistake and I think she likes them both better than hers. LOL She called me on the phone the day after they left and I had to explain how to use them for her . She got lucky I had just put the charger for the video camera back in the bag about 2 days prior
    Good luck to you and keep posting some of those practice pictures I will be watching this thread as I think I want to try doing some alum soon and any tips/critique you get will help me and others as well.
    Thanks for posting and GL on your progression.. Practice etc etc
    Last edited by aaxiss; 05-28-2011 at 12:30 PM. Reason: wireless kb leavng out letters, had to fix
    Don
    MTS 200 workhorse
    Lincoln Buzzbox
    Milwaukee mag drill
    Fullerton, Ca
    USA
    thanks for the tips guys!
    ive read abotut the brake cleaner thing, somthing i've got to do is make a trip to HF and get some brushes and whatnot to dedicate to cleaning.
    im going to attempt to repair a friends exhaust this weekend, ill see if i can get some in progress pics as i go.
    300whp FWD 94 Celica
    Thumbs up
    hey guys, didnt get any pics of the exhaust repair, it was mostly ugly welds on rusty metal. lol
    i did manage to get some practice with some aluminum tubing, a friend is finishing up a swap, and is going to need some intercooler piping tigged up, so he brought me a peice of the aluminum piping he bought thru ebay for it.
    being a noob, it took a few passes to get into some settings that worked for me, but i was able to get a bead going after a short while, and although my technique is still very incosistant, i can see improvements after every bead, and for now, thats all i can ask for!
    here are the settings i ended up using.
    ~80 amps (playing with the footpedal to control things once i get going)
    1/16" 2% thoriated tungsten (still need to get some lanth here soon to try)
    #6 cup IIRC
    3/32" 4043 filler rod (all i have ATM)
    ac freq ~ 100
    ac balance ~ 40%
    just a hair of pre flow, and ~3-5 sec of post flow
    .065" wall aluminum tubing
    here are a few pics.
    Attachment 2011Attachment 2012Attachment 2013Attachment 2014
    still dipping the tungsten occasionally thruout, and keeping the torch angle consistant on the round stuff is proving to be a freeking challange from god himself!! lol
    but, i feel like im making progress.
    i know i should be concentrating on running flat beads on sheet steel and aluminum right now, but the ADHD kicks in like crazy if i try and sit and do one thing for too long..lol
    now, a couple questions.
    if i went to a larger tungsten (3/32") would i need less amps? and would the bead be wider/flatter?
    how much gas flow should i be using?
    i have a 60# tank, and emptied it this weekend in just a few hrs of work, is that normal? (im going to step up in size on the next refill)
    Any input on my questions, guys?
    Also are those "gas saver" lenses any good? Do you actually save gas with em?
    1/16 tungsten seems appropriate for what your welding now material thickness wise, but yes a larger tungsten will create a wider arc given the same voltage but overall less penetration. usually you you will get a wider bead and a bigger cleaning etch zone the bigger you go with your tungsten electrode. of course that is controllable with more EN and frequency . What are you looking for in your welds, how would you want them to be different ?
    argon flow rate : well with argon being 1-1/3 heavier than air it naturally wants to flow down and cover the weld puddle 15--20 CFH or cubic feet per hour should suffice. for vert or over head start at 20 and go from there. To answer Your other question You seem to have some decent welds so I am guessing you somewhere in that 15-20 CFH zone... So if you think you did 3 hours of welding I would expect your tank to be empty if it's a 60cf tank
    The gas lens Well a lens is designed to evenly distribute the gas flow around the weld zone and will actually allow you more tungsten stick out up to an inch or more with proper gas flow for greater visibility in certain welding situations and the more pricey engineered porous media filters lenses create a much better laminar flow and may allow you to turn down your gas flow because of the superior shielding effects of the lens body vs a standard collet body. But also keep in mind lenses are considered consumables and will get contaminated and need to be replaced occasionally and will increase the cost factor most likely , because being new to tig and still dipping the tungsten as you say you are can actually cause your welds to look worse and show a really erratic cleaning etch because of a contaminated screen/filter . Keep in mind also each tungsten size needs the proper lens size so as a beginner you can see how costs could add up fast. If anything I would definitely go to a bigger tank at least 150cf and concentrate on the welder settings a bit more and just practice practice practice
    I think after looking at your welds it just comes down to speed technique and the ability to stay fluid and smooth over longer beads and thinner filler or dropping the frequency will help create a flatter weld by having a wider less focused arc but the cleaning etch will get bigger also
    I hope I have answered some f you questions to your satisfaction. Try the Miller welding site under the resources tab . Just about everything about welding can be found there
    Don
    MTS 200 workhorse
    Lincoln Buzzbox
    Milwaukee mag drill
    Fullerton, Ca
    USA
  8. #28
    Don, thanks so much for the detailed response, I appreciate it.
    Definitely will be getting a larger tank here soon, got a little practice tonight, getting smoother every time I pick up the torch.
    Gonna get some fresh metal to practice on this weekend.
    Once I am up and around I will be starting in on aluminum once I get my new welding table built. That's another Project I been working on as funds allow .
    Your weld quality has progressed quite well and I hope to progress as quickly Having only done a smidgin of aluminum welding many years ago before losing the ability to use a foot pedal. Will be a great learning experience.
    Cheers and keep up the practice and get to know every setting on your machine and you will be welding like a pro in no time
    Don
    MTS 200 workhorse
    Lincoln Buzzbox
    Milwaukee mag drill
    Fullerton, Ca
    USA
  10. #30
    got more practice in today, another hr or so, starting to get a little more consistant and co-ordinated with both hands, i think once i get some extra cash to either build a welding table, or at least get one of those portable "nomad" welding table like jody uses, it will really help, right now im welding on a wood topped bench thats way to high for me, with a peice of 3/8" steel laying on top that i use as a ground point/heat sink
    so settings are as follows:
    3/16" aluminum diamond plate (welding on the backside)
    3/32" 2% thoriated tungsten, ground to a dull point
    3/23" 4043 filler rod
    160amps max footpedal controlled
    a/c frequency @ ~125
    a/c balance @ ~ 40%
    a few pics:
    the first is the overall pratice, the last couple are my best bead so far.
    got a little hot there right at the beginning, started working the pedal back a little late.
    still need some work filling that crater there at the end, i gotta work on putting in that little bit of extra filler as i work the pedal more.
    getting there!!
    thanks for all the tips so far guys, its helping and working! keep em coming!!
  11. #31
    I need to spend a lot of time practicing. Your welds are looking good from my opinion. I also need a table and was thinking about getting something that folds up or building one so that it does not have to sit out in the way as the shop is getting full. I have been using a vise that is on a bench way high for me. When I had pipe in the vise, it was about my chest level well I was standing and I had a heck of a time on it.
    Quote Originally Posted by presure2 View Post
    Hey all, got my power pro205 in Monday, and have been playing with the tig.
    I've never tig welded before, only welding experience I have is messing around with my 110v mig welder welding up exhausts and what not in the garage.
    A buddy gave me a peice of ~3/16" aluminum diamond plate he had laying around, so that's what I started on. These pics are the first 3hrs of practice.
    Various settings thruout, but the last couple pics are setup with:
    3/16" aluminum diamond plate ( welding on the backside)
    3/32 2% thoriated tungsten, sharpened to a dull point
    3/32 4043 filler
    ~120-125 amps or so
    AC freq. ~1:00
    AC balance ~10:00
    No pulse
    A hair of pre and ~ a few seconds of post flow
    I was pretty happy with the bead in the middle of this pic
    Suggestions and comments are welcome and needed!!!
    At least I feel like the hrs spent on jodys site helped alot, definitely would suggest to anyone starting out to make the time to go thru jodys site and watch and read as much as you can, lots of helpful info and as he calls it, "no bull, no frills, down and dirty welding tips and tricks!"
    For those who don't know who I'm talking about, his site is www.weldingtipsandtricks.com
    Also learned alot from you guys as well!!
    you did better than i did when i first started tigging (my teacher said Aaron you can stick and mig like a villain im gonna leave you alone for the next couple days when i come back you better be able to lay me a bead and spell your name) i miss that woman *yes a woman taught me to weld* i couldn't do anything but just melt the metal and waste the tungsten , keep practicing you'll get there
    Aaron
  13. #33
    yea, thats what its all about! the pics at the bottom of page one are more recent that these ones you quoted, definetly more consistant.
    gonna try and get some practice on 1/8" steel today in a little bit.
  14. #34
    I'm still out of commission, envious of you guys getting to play in your man caves. Presure2 Please add you first name to your sig or I might just start calling you Celica LOL.
    You are making some great progress, I definitely see a lot more steadiness and uniformity in your weld now compared to the first pictures. Well done . P P P
    Don
    MTS 200 workhorse
    Lincoln Buzzbox
    Milwaukee mag drill
    Fullerton, Ca
    USA
  15. #35
    keep burning that's the only way your gonna get better. when you get burnt out from trying to run beads or trying to nail a position. just start welding crap together get creative or jump to really hard position. (just like with a woman try something new it might blow her mind) for me and few others we were having trouble doing the simple positions. but excelled in doing to hard ones like over head and so on.
    aaxiss- man let me tell you i feel ya. been taking radiation treatments for the last month, every since i decided to wire my building to get power out there. my welder has been in the box they shipped it to me in. i haven't even been back to school to finish up my degree, had to leave before the semester ended last year cause i started feeling sick. now i can't go back till i pay back a freaking 200$ student loan i forgot all about lol. from what my doc tells me i may not even be able to be around the welding arc. i def can't handle to heat and sun anymore im only 26 and had 2 brain tumors and surgery's in my life. now i may have to sit on the side line and watch all you guys weld "not trying to hijack your thread Preasure"
    keep up with what your doing
    Aaron
  16. #36
    Not it Hijack either. But keep up the good Fight Aaron, Never take Dr. word 100% at anything he tells you you can't do. You want to weld, go weld (Baby Steps) or at least go open that new welder up, It might inspire ya. Tell the Dr to give ya a Prescription for reglan (anti-nausea) That will help. That sounds screwy what the Dr. said about never being around an arc, It's just very strong UV Radiation (Same as the sun). If ya have to, Put an AC Unit out in your shop to help with the heat issues. There is also clothing and devices to help control body temp Issues. I use some .
    Do you want to go back to school? If your Able?, If you do
    I'll help ya get the $200.00 I hope it's not 200k.
    ( Have you Tried Writing a formal Financial Hardship Letter to the school?)
    If you Send Me a Copy of The Bill or Last letter with balance ETC. I'll set up a Charitable foundation for you so I can legally ask for money to help pay that off for ya. I'm sure Everlast Would Give a dollar as would most active members to help get ya back to school.
    " Never be too proud to accept help when offered, but never be too selfish to offer help when needed "
    Let me Know if I can Help in any way Aaron, Please
    HIjack over
    Don
    MTS 200 workhorse
    Lincoln Buzzbox
    Milwaukee mag drill
    Fullerton, Ca
    USA
  17. #37
    No worries, guys, it's all good.
    We're a community here. If I can help out in some way, let me know.
  18. #38
    Yota,
    I think he is worried about you being photosensitive, or possibly having an epileptic seizure. In either case, there is something to be done about it. Cover up and wear sunscreen, you should be fine on that account. Just don't forget the area below your neck. If its a seizure related thing, then unless you use pulse or something, the chance is remote. Pulse welding can cause epileptic fits at the right frequency.
  19. #39
    yep i have medication that effects me that way also when I have kidney infections. Columbia outdoor wear makes a super light weight UV protect long sleeve shirt ( I have 4 ) That actually makes you feel really cool , even in mid-summer 95 deg heat .
    Here is a link to just one style http://outlet.altrec.com/columbia/me...ng-sleeve-crew
    and to protect your neck from flash burn I just pop-riveted a piece of fairly soft cowhide leather from an old welding apron about 3" at the sides and 6" in the Center to protect my neck,
    For 19.00 shipped I got a nice pair or Goatskin slip on single sleeves and love them
    http://www.amazon.com/Tillman-Goatsk...422740&sr=8-35
    now we got ya covered literally
    eat lots of protein. you need energy during Chemotherapy treatments. 14oz Ensure high protein low cal 210 + 2 oz beef jerky total 350 cal and 55g protein only 6g fat total ( plus the ensure has a ton of vitamins) So if you do the Ensure as breakfast to get ya going and he jerky as a couple of shop snax with sensible lunch an dinner you will notice a difference in your energy level. of course you can buy protein mix which is cheaper but not so tasty .
    here's my bedside table, I speak from experience, the high protein, low fat menu helped me heal up faster and I just feel more energetic .
    Attachment 2273
    Cheers and Pm me if you need anything within my capacity to help you with....
    Don
    MTS 200 workhorse
    Lincoln Buzzbox
    Milwaukee mag drill
    Fullerton, Ca
    USA
  20. #40
    The Boonies of Texas
    Here is in my opinion one of the best and easiest protein sources to use. I buy 5000 tablets at a time. Should be very useful for chemotherapy patients. http://www.nutrex-hawaii.com/spirulina.html
    Thurmond
    Miller Bobcat 3 Phase,
    EVERLAST PowerUltra 205P
  1. Torch questions
    By DJLVA in forum Pre-sales, Sales and Shipping questions
    Last Post: 07-09-2017, 11:07 PM
  2. Different torch questions
    By Gunther in forum Pre-sales, Sales and Shipping questions
    Last Post: 07-05-2017, 09:10 PM
  3. Model 26 Torch & General Torch Questions...
    Last Post: 08-26-2012, 03:47 PM
  4. more torch questions
    Last Post: 08-07-2011, 09:52 PM
  5. first tig fusion bead attempts.
    Last Post: 08-01-2011, 03:57 AM
