I'm having an intermittent HF start issue on my new 250EX. Do you have instructions on how to check the "points" gap on the HF board?
Darren
Darren
till support gets a better awsner take look at this thread
http://www.everlastgenerators.com/fo...ghlight=points
on the new 250ex the point gap is is towards the front of the machine above the connectors. On mine there is a pretty loud buzz when you hit the torch button and there is a blue flash you can see from the side vents
also if you are using the button on the torch check to see if its clicking when you think it should...I had some problems if I would click it towards the back of the switch. It didnt seems to click or it would stay clicked if I used the back half of the switch , but clicking the front of the switch seems to work ok
sold my miller mig
got a PT250EX
saving up for a plasma cutter
Darren,
That thread pretty much covers the point. If you still have a problem locating them, call into tech support and one of us can walk you though it. Also, make sure the unit is unplugged for 20 minutes before adjusting them.
__________________________
Everlast Power I-MIG 200
Everlast PowerUltra 205P
Everlast SM 200-N
Thermal Dynamics Cutmaster 42
Everlast lx225
Hobart Stickmate LX
Thermal Arc 400GMS
10"-22" Grizzly lathe
Checked and adjusted the gap. Didn't seem way out but was hard to get a good measurement worrying about touching anything else. Back together and it seems to be consistent now. Really impressed with the smooth controllable arc in DC mode. Need to line up some projects instead of running these practice beads and searching for perfection.
As someone who was trained on a Miller Synchrowave, this 250EX is awesome! Great value and performance.
Darren
Off topic and all Darren but ya gotta get that instrument rating! Good luck with 250EX!
PowerTig 225LX
PowerCool W300
PowerPlasma 60S
Miller 140 MIG
My "vfrguy" name came from the Honda VFR I've been obsessing over for years. Always wanted to get a pilot's license but never pulled the trigger.
Darren
Darren,
What are your AC balance settings? Do you have your torch in the negative?
Mark
877-755-9353 x204
M-F 9am - 5pm EST
Balance is at 30%. Torch in negative.
Darren
There are in fact bleeder resistors across the caps, and they bleed down pretty fast. but there’s always that one time that something is not at 100% and Zap.
With customers inside the machine we always try to err on the side of caution.
Hey, Mike used to say 2 hours, got him down from that LOL, but it’s better to be safe than sorry.
____
Ray
support@everlastalaska.com
www.everlastalaska.com
877-755-9353 X207
Like if you get the one machine missing the resistors.![]()
Yeah, used to charge up 450V caps in high school shop class and leave them laying around for someone to pick up the wrong way.
Lincoln Weld-Pak 100 (C-25 or CO2 Shield)
Victor Oxy-Act
Lincoln AC225 Tombstone
Everlast 250EX & W300 Cooler
