Results 1 to 16 of 16
Thread: Project 10 from d3javoodoo " Another Work in Progress"
    Default Project 10 from d3javoodoo " Another Work in Progress"
    Hello forum.... here are a few images of another piece I'm currently working on simultaneously with project one in conjunction with a current series of mine.
Name:	work in progress.jpg
    I often work on multiple pieces @ once during a series so they can compliment one another to some degree. This sculpture when finish will be constructed of bronze, & steel. I have not choosen a tittle for it as it is still incomplete. I would estimate any where from 10-25 hrs. until completion @ this point.
    Springfield, Illinois
    Neat, may I ask how it was formed??
    The bronze piece was cast in silicon bronze, after being formed in wax. The rest is all mild steel... so far.
    Looks like a face of a sleestak
    The Boonies of Texas
    Land of the Lost, I remember it well!
    Thurmond
    Miller Bobcat 3 Phase,
    EVERLAST PowerUltra 205P
    Kind of looks like a teenage mutant ninja turtle skull...
    Everlast PP256
    Everlast Imig 205
    HF 90 am inverter tig
    Scopes, Scanners, Meters
    That is interesting but I think I like it. Did you do the casting work yourself?
    what size is it? hard to get a perspective in the pics
    sold my miller mig
    got a PT250EX
    saving up for a plasma cutter
    Lost wax casting right??
    Yup lost wax.... this piece is currently less than eight" tall.... similar to other pieces in the series. A while back when I was set up to do casting work, a lot of pieces were cast in multiples... because in casting your never guaranteed a perfect cast so normally people cast multiple parts in case an air bubble gets caught up in the shell when pouring.
    May I ask if you use other methods for casting??
    Oxide, Lost foam is a great casting method too (for machine parts anyway). First you carve the foam with either a hot wire or CNC router. Coat with Drywall compound then sand cast as usual. Very clean castings.
    Thurmond
    I've used most of the known methods... lost wax, vacuum, sand. Lost wax seems to be the most versatile, but my favorite it vacuum casting. Vacuum casting can be done on a small scale, but the best part is that vacuum casting offers up MUCH more detail than regular lost wax casting.
    Oh yes I really want to do lost foam casting once I finally build my foundry. Vacuum casting sounds really interesting as I have rarely heard of it.
    Vacuum casting is normally done with Jewelry where many waxes are built on a wax tree in a mold. It allows the molten metal to be pulled into many minute details and crevasses for very fine detail.
    Thurmond
    Hmmm, thanks tritium ill have to read up on that.
  1. First 'project' ........ shortening a "hand truck"
    By johnnymg in forum Hobyist Projects
    Last Post: 07-08-2013, 02:25 PM
  2. First "real" TIG welding project coming up.
    By 225 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 12-27-2012, 08:48 PM
  3. Project From EmptyNester - Belt "guide" for hovercraft
    Last Post: 10-10-2012, 05:01 AM
  4. Project 1 from d3javoodoo *A Work in Progress*
    By Legacyartist247 in forum Metal Art
    Last Post: 07-17-2011, 01:38 AM
  5. Replies: 0
    Last Post: 06-09-2011, 07:33 PM
