Results 1 to 15 of 15
Thread: PowerUltra 205
    Default PowerUltra 205
    deleted...
    __________________________
    Everlast Power I-MIG 200
    Everlast PowerUltra 205P
    Everlast SM 200-N
    Thermal Dynamics Cutmaster 42
    The Boonies of Texas
    I just upgraded from my SC 50P Plasma cutter to a Power Ultra 205P. Oleg tells me that Pulse (P) has been added to which I responded "SWEET". Mine is supposed to be here Tuesday. I will report back as I learn to use it.
    Thurmond
    Miller Bobcat 3 Phase,
    EVERLAST PowerUltra 205P
    one day soon I hope to purchase an EX 250 and semi- retire my Pu205 to plasma only duties. I'm sure it will handle the job just fine. A standalone Plasma cutter would be great, but I already have the PU205 and it cuts anything I need it to. On top of that I am finding the portability and dual voltage capability of the 205 to be extremely useful. For example, If you do happen to take the little welder to a worksite to do some stick welding, as I will be next week, you have a cutter and really nice tig welder there too.
    Here is a demonstration cut I made with the PU205 http://www.everlastgenerators.com/fo...0&d=1276752830
    Kind of amazing really, you can do all sorts of fairly heavy duty welding/cutting and still pack the thing around easily with the shoulder strap.
    Glen
    Everlast PP256
    Everlast Imig 200
    Everlast Power Ultra 205
    P&H 400 amp A.C.
    i have a pu205 and love the plasma. thought i was having an issue with it because it wasn't cutting very good and the tig was exploding my tunstens. i put a dessicant dryer on it and all the cutting problems were solved, i don't have an argon bottle to see if the dry airlines fixed the tig problem but i have a sneaky suspicion that'll be fixed as well. my cuts aren't anywhere near as pretty as worntorn's but it gets the job done just fine
    everlast i-mig 200
    96 gmc extended cab truck 350 rwhp daily driven for 289,000 miles
    88 jeep cherokee custom built by me for me for well everything.someday it'll be finished
    4.6L stroker,dana 44 front, 14 bolt rear, 35"xterrains,soon to come 231/205 doubler
    shawn,
    Its either going to be a problem with the wrong shielding gas or wrong polarity.
    i figured having water in the air line might do the same thing. i do have a bottle of 75/25 i use for my mig. last i read i had to have straight argon for mild steel on the tig process is there anything i can use the 75/25 on to see if the problem is still there? i have 2% thoriated for tungsten
    everlast i-mig 200
    NO. nothing. You can NOT use the CO2 mix with tig
    that's what i thought. guess i just need to save up for another argon bottle
    everlast i-mig 200
    Renting/leasing is usually better and less hassle.
    down here it's a $50 difference so might as well just buy the bottle. $200 deposite + $10 monthly rental fee + $22 refill or $280 to buy a full 125 bottle
    everlast i-mig 200
    Where's down here? You are getting ripped. Simple credit check and a cylinder should be NO more than 70.00/year, no fee up front for MAX size cylinder.
    Quote Originally Posted by shawn View Post
    You need to shop around. I can buy a 330cf filled for $300 here in SoCal.
    Gerald
    Millermatic 251
    Spectrum 300 Plasma
    Everlast PowerTig 250EX
    Everlast PowerCool W300
    Harris / Victor OA
    ProTools Air/Hydraulic Bender
    Airgas Southwest is only $49 a year for lease of a size 200 and charged less than 14 dollars for my first fillup of 100% Argon.
    Thurmond
    i called all the welding supplies and they all gave me the same price...guess it doesn't help that my credit is shot
    everlast i-mig 200
    Yes, it does. Ken, I think you will be happier with separate units. Most people are. Never had one complain yet that they bought separate and should have bought together. I have had it the other way around though.
  1. New Powerultra 205's
    By ljdm1956 in forum Pre-sales, Sales and Shipping questions
    Last Post: 02-15-2014, 05:12 AM
  2. PowerUltra 205 arrived
    By jdom in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 11-25-2013, 05:07 PM
  3. powerultra 205 vs powerultra 205p
    Last Post: 03-22-2013, 02:08 AM
  4. powerultra 205
    By travis in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-28-2013, 09:33 PM
  5. powerultra 205
    By gwk in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 09-25-2009, 02:02 PM
