Thread: Project 2 from d3javoodoo (Portable weld cart)
    Default Project 2 from d3javoodoo (Portable weld cart)
    Hello Forum...
    Here's another project of mine I put together shortly after my new Everlast Power Pro 256 arrived last spring. I managed to scrounge up enough pieces of scrap metal I had laying around to build a small, sturdy, portable cart for the new 256. Seems to work fine so far... gets the job done. However I do plan on adding sheet metal to enclose the lower half, & create a toolbox for tools, as well as designating space for a modified water cooler. I opted to build something as small as possible for ultra portability on those days when i have to take it to a jobsite. The cart measures 28"x10"x19", & stock was (3/16" thick x 1.5"crs). So far I've got about 4.5hrs. into it, & plan on seting aside @ least another 2-3hrs. for mods. As for gas, I prefer to use an extended hose for extra mobility now that I've got a trigger.
    Attachment 2191 Attachment 2193
    Attachment 2194 Attachment 2192
    thats interesting, how does it roll around and what did u use to paint it? Looks like a wrinkle black powder coat from the pictures but i am probably wrong
    Brandon Raineri
    Everlast PowerPro 205
    Everlast I-Mig 200
    SpeedGlas 9100x
    Milwaukee 14" Dry Cut Saw
    by now I have built a cooler for the tig, Click image for larger version.
    with the dolly the whole setup is even more maneuverable than I expected...
    The next obvious step would be to maximize reservoir volume by fabricating a stainless, or aluminum box like reservoir that would fit more precisely in the rear of the lower cart. Then I may, or may not box in the enclosure.....
  1. Project #1 yes! A portable welding cart/table
    By ironmanjay in forum Hobyist Projects
    Last Post: 06-01-2013, 07:46 PM
  2. Project #2: Weld Cart/Tool Cabinet
    By brianscott in forum Other Custom Fabrications
    Last Post: 04-27-2012, 11:41 PM
  3. Project 5 from d3javoodoo ( DiY tig torch cooler)
    Last Post: 09-28-2011, 08:41 PM
  4. Project 14 from d3javoodoo @ Portable Camera Phone Mount @
    Last Post: 07-30-2011, 09:04 PM
  5. Project 8 from d3javoodoo % Side job%
    Last Post: 07-21-2011, 10:23 PM
