Originally Posted by
You can do this manually, the flat granite piece acts like a sanding block? I'll have to keep that trick in mind. How long did that take, and how did you check to make sure it was flat enough?
When people post pictures I always check into the background to see what else is going on in the picture... and I think I'll check our ironing board to see if it is expanded metal. That was an excellent find!
I have surfaced the cylinder head and the block deck by hand on motorcycles. Actually, the head and cylinder currently on the bike was done in my basemen by hand. I go up to 600 grit. Has worked for almost 200 dyno pulls and probably 60 passes at the track.
