I have a 2002 TDI Jetta and have cleaned mine as well. Now has 183,000 miles on it and doesn't have nearly as much of a problem with the sludge since I turned the EGR valve duty cycle way down.
the cars will still run like that. That one is just getting to the point where it starts to decrease performance. These things only make about 90 HP and they are turbocharged. Doesn't require a very big air passage.
I believe the new diesels have a filter to prevent the sludge. There are a few people that make one for the engines that have the problem, but turning down the EGR operation in the ECU works as well.
Jakeru, if you do the burn out method in the future, use a very wet rag on the outside of the manifold and continually wet the rag as you go to prevent melting it. I don't think I have seen anyone melt one that much! OOPS!
