Thread: project #1 from Aaxiss Wheelchair seat pan
    Default project #1 from Aaxiss Wheelchair seat pan
    Ok first off I did this project to save myself $145.00 for an 18 x 18 " piece of aluminum, (That's what the local shop wanted for a new item). I needed an 18 x 18" seat pan for an old power wheelchair I'm trying to get usable again and found a 20 x 18" pan on Craigslist for $20
    This is what I started with. Showing some of the Scribing of the new hole locations before any cutting is to be done, just lines transferred over and main cut line.
ID:	2595Click image for larger version.
    Since I'm at my apt I am stuck using low tech for now, the next two shots show the cut in progress using a $12 HF jig saw with a decent bi-metal blade.
ID:	2597Click image for larger version.
    next two shots show the cut off piece laid over the main panel to verify my marks for drilling.
ID:	2600Click image for larger version.
    Using the Harbor Freight 2 in 1 Disc/belt sander to redius the corners.
    Using my spring loaded center punch to mark the drilling points for the index holes on the seat pan, and readying my drill.
ID:	2603Click image for larger version.
    I needed 1/4" holes so I opted for the large HF step drill bit as it would bore the hole and de-burr at the same time.
    to be Continued
    Don
    MTS 200 workhorse
    PowerTig 250EX <---sweet
    80 amp HF inverter arc welder
    Lincoln Buzzbox
    Rotobrute AC-35 Mag Drill
    Milwaukee mag drill
    Fullerton, Ca
    USA
    ok back to the drilling. as i Said I am using the HF step drill bit because it makes a nice clean hole and de-burrs the hole at the same time
ID:	2606Click image for larger version.
    After drilling the holes I still had to clean up the back side of the hole and for that I used a single edge countersink bit
ID:	2607Click image for larger version.
    And last of all I cleaned up the edges with a file so there will be no sharp bits next to my legs, and the finished product
ID:	2610Click image for larger version.
    May not seem like a big deal, but I saved $125 over the Mfg cost of $145 by buying something I could modify and reuse for my needs. Hope this small project shows that It doesn't always have to be new to be right
    Don
    MTS 200 workhorse
    Lincoln Buzzbox
    Milwaukee mag drill
    Fullerton, Ca
    USA
    Quote Originally Posted by aaxiss View Post
    ... that It doesn't always have to be new to be right
    Good on ya! I always get satisfaction out of making something useful from something that had been abandoned or written off.
    In WWII my great uncle was deferred from service- he had a vision disability that kept him out of the service but that didn't prevent him from being a fire fighter- go figure. So in between fires he repaired household appliances as a side business, and managed to save a tidy sum.
    Haven't seen you around for a while, Don, I hope this means you're back in fighting-form!
    Well I think I can maybe go a 3 rounder LOL. Still Limited on my sitting time. Have to get out of my wheelchair every hour for 30 min . So I try to make those hours at a time up count. The wheelchair I am working on now will have a tilt in space system on it. Got at a local garage sale fo $40 hahaha, Retail is 2900 but that would be with the mount kit for my chair. I have to make all my mounting hardware no biggie. $50 in various aluminum blocks. now I just need to get at the Mill For some quality time
    Gonna try and Finish my water cooler this month also
    Have a good day Dave
    Don
    MTS 200 workhorse
    Lincoln Buzzbox
    Milwaukee mag drill
    Fullerton, Ca
    USA
  1. Replies: 8
    Last Post: 12-05-2012, 06:04 AM
  2. Project 3 from Bob Wills dec 3 contest- seat bracket
    Last Post: 02-10-2012, 12:57 AM
  3. Golf Cart rear seat project.
    Last Post: 12-30-2011, 06:55 PM
  4. Jeep seat frame project by Chadrock.
    Last Post: 07-15-2011, 12:58 PM
  5. Project 2, Tractor Seat Stool, from Tritium
    By Tritium in forum Other Custom Fabrications
    Last Post: 06-16-2011, 07:36 PM
