Results 1 to 5 of 5
Thread: Question on the Power TIG and Master torch
    Default Question on the Power TIG and Master torch
    Quote Originally Posted by JJW View Post
    I'm looking at TIG torch handles, and need to see some information like: it’s Amp rating, if it is air cooled or water cooled and if it has a contact switch built in, contact switch strapped on or no contact switch at all.
    All of our new torches are air or water cooler compatible. And the buttons are built in (there is a picture on our website under details). Only one model is not. Which one are you looking at?
    On your Welders there are two units that I wanted to know what TIG torch handles they come with: the PowerTig250EX and the PowerMaster226
    Thanks in advance,
    Both are air/water compatible. I will check the rating, but I thought it was 300amp +. Mark might know it off the top of his head. Otherwise I will look it up. Surprised it is not on the page yet.
    Both the PowerMaster and the PowerTig carry the extremely ergonomic Trafimet/Binzel designed water cooled torches. The parts are interchangeable with weldcraft.
    The rating for water cooling on this torch is set at the factory with a 300 amp capability. The factory said it was okay to use up to 160 amps air cooled. It will work at that amperage, but the duty cycle is low when it is air cooled, from my experience.
    Here's a picture from the top of the start button, which is not used when the footpedal is engaged. The foot pedal initiates the arc when it is depressed.
Name:	torch issues 005.jpg
    Thanks Performance & everlastsupport!
    The picture helped me too.
    Now just to decide which unit the PowerMaster or PowerTig.
    Regards,
    John
    If I had to make my choice, it would be difficult. I think having separate units gives the slight edge in my book. But that is MHO. Obviously we sell both, so there is a market for both. The EX has the slight edge on features...if you take away the plasma cutter. But then again that is a major feature...
    As far as all-in-one or separate units:
    All-in-one units are great. Take up less space, you can take it all with you and only one trip to the truck. Down side, IF something where to died, you are out a welder/plasma for a week unless. If we ID the board and send a new board and still will take about a week to get it but at least you can use the other functions (assuming a inverter problem). Also, you have to swap torches when switching processes.
    I have mine as separate units since day one, however, I am thinking about going all-in-one. I have a 3 tier welding cart, it rolls fine with everything on it, but I have to get on my knees to setup for TIG, the TIG will not fit on the middle shelf and I like the MIG on top.
    Either type units are good a good choice. I will probably go all-in-one (never thought I would say that) in the next couple months. Space and less weight to drag, and I can pile more things on the carts empty shelves The IGBT line being rock solid helps in that choice too.
  1. Power MTS-200 & 250 MIG TIG question
    By m10za in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 03-14-2015, 01:16 AM
  2. Pencil torch question
    By SportPilot in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 06-22-2013, 06:25 PM
  3. New WP9 torch question...
    By rengaw21001 in forum General Welder Questions
    Last Post: 11-10-2010, 03:35 AM
  4. Power Master 205 New User Review
    By 91TSiGuy in forum Customer Testimonials
    Last Post: 03-12-2010, 05:43 PM
  5. New Power Master 205
    By Skisareus5 in forum Introduce Yourself
    Last Post: 03-01-2010, 04:09 AM
