Results 1 to 1 of 1
Thread: Project 15 from d3javoodoo % Aluminum Wheel repair #2 %
    Default Project 15 from d3javoodoo % Aluminum Wheel repair #2 %
    This morning I took an hour out to begin some repair work for a set of wheels I got for free years ago from a friend who runs his own machine shop.
    I have decided these will make a good set if I put a little elbow grease into it...
ID:	3060 Click image for larger version.
    You can see from the above photos that the tapped holes are not centered correctly on this one individual wheel...
ID:	3064 Click image for larger version.
    The cure I came up with was to add some weld, & then grind off excess, then polish, & or sandblast ...
    I didn't take the time to get that stack of nickels look because all that excess meat will be ground off... but I was sure to achieve good fusion. These wheels currently are 4" x 2.25" x 1/4" well thickness (aluminum). I plan to set aside @ least 5 hours in the future to make these wheels look GOOD.
  1. Aluminum wheel crack repair
    Last Post: 06-18-2013, 11:46 PM
  2. Using Helium for Aluminum Wheel Repair (jakeru's #19)
    Last Post: 02-18-2012, 05:29 AM
  3. Project 7 from d3javoodoo ^custom wheel design^
    By Legacyartist247 in forum Other Custom Fabrications
    Last Post: 07-30-2011, 07:31 AM
  4. Project 12 from d3javoodoo ^ Jig for sm. Scale Wheel (5 spoke) ^
    Last Post: 07-27-2011, 04:46 AM
  5. Project 6 from d3javoodoo * Alloy wheel repair*
    Last Post: 07-21-2011, 04:46 PM
