What is the maximum wire speed for the I mig 200?
Approx. 600 ipm
Mark
877-755-9353 x204
M-F 9am - 5pm EST
the highest I get is 330 IPM with the readout at 305
any ideas on how to correct that? It feeds smooth and does not seem to be slipping.
I time 6 seconds cut and measure the wire and multiply that by 10.
Mark I sent you an email yesterday with a few other questions Hope to hear from you soon
Ray
for reference, mine puts out 660 IPM at -299 on the dial.
McGuire Irvine
Crow Motor Co.
Lincoln powermig 225 (work)
Ken,
Yes...Denotes wire speed. When the unit welds, it will switch over to actual amps...no -.
Mark
877-755-9353 x204
M-F 9am - 5pm EST
Ken
Mark and Ray looked into it and my machine is within the acceptable IPM for our class of welders. My Max IPM is 335 and will allow me to weld at max amps with the correct wire size.
Ray
The original specs we expected for the units were to be within the 500-600 ipm range. Also, for a .023 drive roller... As people can see, its standard with an .030 minimum. What is at the heart of the issue is that the larger wire sizes do not require the same wire speed as the smaller diameter, and the drive mechanisms are manufactured by Binzel, or a licensee of it. The maximum voltage they are rated for is 24V...They will not turn faster than the 24V allows when the rheostat is turned wide open. The factory states that there is a 10% allowance for wire speed roughly on either side...But within the limits of the .030 minimum wire size, its fine for operation, but not for .023...And the reason its been like pulling teeth to get the .023 drive rolls from them I suspect. As for aluminum operation and the spool guns...It seems that .035-.040 aluminum wire is what is necessary to use as well. We are working to see the maximum wire speed we can get out of the current drives without changing them out. It seems the target wire speed is somewhere around 350 ipm...When the factory gives us a spec it comes to us in Mpm. They don't get hung up on a tenth or two..which to us seems like a lot of ipm when converted, but when you are talking a larger, meter unit, its not significant. FWIW, we originally verified the wire feed speed much higher than it is now, but my proto unit probably had been a little different feeder too from some of the production units.
I want to emphasize that the MIG welders DO work well and that you will be hard pressed to find anything negative about them. Arc stability, controllability and overall function is unsurpassed. If your comparing only the wire speed, remember, the little 140's and 180 units offered in the price range similar to ours that offer 600 ipm or so, start out offering a 2 lb roll capability, and .023-.030 wire option and about a 10% duty cycle or less at maximum amps. We offer .030-.040 drive rolls which will handle up to .045, which require less wire speed to get the same results.
Additionally, I'd add that for those thinking they MUST have the .023 wire, have not tried the .030 yet. I've welded quite easily 20 gauge material with the .030...
While we're talking MIG, I'd also like to put a bug into some peoples ears about Gas selection for these units. I have used both 75/25 and an airgas proprietary blend of c18. Both weld fine, but, if you've never tried a lower percentage of CO2 in your mix, you will whip yourself for not trying it earlier when you do. Other companies have an 85/15 and some and 80/20...But the experience of a higher argon content will change many peoples view and enjoyment of MIG welding.
Mark
877-755-9353 x204
M-F 9am - 5pm EST
huh, learn something new every day... I didn't know it did that at all. I'll have to point my phone camera at it next time I'm welding to see what amperage I'm at.
McGuire Irvine
Crow Motor Co.
While MIG welding too.
Mark
877-755-9353 x204
M-F 9am - 5pm EST
I just checked out my Imig 205 and the dial max's out at 304 and the wire speed is 405 IPM . more than enough IPM for any wire size to burn within the limits of the welder.
Once again all I can say is: the trick is, to use the right size of wire for the job, trying to weld thicker material with a small wire at high speed just doesn't work out.
does the voltage setting make a difference? Atleast on my HH 210, changing the voltage setting changes the feed rate without touching the wire feed knob.
Everlast lx225
Hobart Stickmate LX
Thermal Arc 400GMS
10"-22" Grizzly lathe
[QUOTE=kenwhite;13632]I just checked my I-MIG 200 for Ray and the maximum IPM wire speed my box can do is approximately 370. I checked it 3 times with a stop watch at 6 seconds and the length was between 36" and 37" all three times.
So, it looks like my IPM is low too...
Did you guys ever figure out what is causing this?
Your IPM is correct for the size of machine you have, 370 IPM is the top end of a .035 wire @180 amps see this
,http://www.airgas.com/content/detail...=7000000000143
and this http://www.airgas.com/content/detail...=7000000000144 which shows material thichness and wire
To get the best performance out of these machines at MAX amps they should use a 1.0 mm wire/ 0.040 wire, which isn't on the airgas chart.
Trying to run a small wire at highspeed is not a good idea, as the wire size limits it's amps. again see the airgas chart for the amp ranages for each wire size and it will become clear as to what speed you need for each wire size after which you should up your wire size to match the amps you want.
Every wire size has a sweet spot amp range, the trick is to find a wire size that meets your needs.
