Results 1 to 20 of 20
Thread: First Welding Project - You guessed it... a welding cart
    Default First Welding Project - You guessed it... a welding cart
ID:	3267Click image for larger version.
    So, I did some practice welding first, but I've always favored working on something real as a way to learn. (I'll probaby post some of my welds for feedback later.)
    The finished product was a welding cart. I had 2" x 3/16 square tube for a trailer tongue extension and decided to use that for the base. I felt the weight would add good stability. The rest of the cart is 1 1/4" 14 ga. square tube and some 3/16" angle.
    The one mistake I made was putting the middle shelf too low (put the top of the tube at the mark for the bottom of the tube). As a result, I had to cut off the angle that was to hold the wood shelf. Later, I'll make a shelf and screw it on top of the tube.
    I still haven't figure out the best way to hang the cables (MIG & Plasma torch and power cables.)
    Anybody know if there's somewhere to buy plastic plugs for square tube? I thought that would add a little to the finished look.
    Just starting in Aug '10
    Hobart Handler 187
    Nice cart... I'd weld a steel patch over those tube ends and then smooth it out with the grinder.
    http://www.mcmaster.com/#tube-end-covers/=e4xpsj
    Brandon Raineri
    Everlast PowerPro 205
    Everlast I-Mig 200
    SpeedGlas 9100x
    Milwaukee 14" Dry Cut Saw
    Nice cart. I keep saying that I am going to build one and one day I will. I agree about covering the ends and also maybe adding a plate to the middle shelf. Maybe that was your intentions in the first place.
    Looks simple and sturdy, nice job. If you do figure out a good place for the cables, please post it. I've been scratching my head over that part of a design too.
    Quote Originally Posted by scootarida1 View Post
    Wow, something from McMaster that isn't horrendously overpriced, too bad they only come in 100 packs. I wouldn't be surprised if Home Depot or your regular hardware store had at least a few sizes.
    Jason - I originally had angle across the middle shelf so that I could drop a piece of wood in. But I mounted the shelf too low and the angle kept me from putting the plasma on the bottom shelf. So, I cut the angle. I just haven't gotten around to making a wood shelf to go on top of the tube.
    Ed - thanks for the tip on the caps. It looks like there are a couple different people who sell them. Probably turns out that it makes more sense to get 100 at a time once you figure the UPS cost of just buying a couple.
    Hobart Handler 187
    How about some hooks on the bottom of the top shelf either to one side or just behind the handle on the front?
    You did an awesome job! What is the tilt on the top shelf for? You could use bolts on the sides to hold the cables...Like 6" long 3/8" - 1/2" diameter. Of course that would make it wider... Or big hooks like Jason said. Actually, you could take 1/4"- 3/8" steel rod, bend them into custom shape and size hooks and weld them on. Sorry for the repaint job...
    Benjamin
    MigPlazArc - thanks. I thought the hooks made from mild steel would be the nicest, but figured that I'd need a touch to bend it. I don't have a torch, so I was thinking about plan B.
    I had seen the angle on carts other folks had made and thought it looked good. It is a pain to look at, and adjust the PP50 since its on the buttom shelf and not angled. The angle just angles the front so it faces you when your standing and adjust it.
    Jason - I think I'll take your advice and put a hook on the underside of the front for the MIG ground cable.
    Hobart Handler 187
    Oh I see. And if you used 1/4" rod you most likely would not need a torch... I would take the rod and put it on something with a gap in between two metal pieces. like a vice...Just hit it with a hammer (not to hard) while holding it with a vice grip. If you need some heat a propane torch would work. They are reasonable priced...You could get one at a hardware store with the torch head and the 14.1 OZ bottle for 15-30 bucks. The tanks only cost like 3-5 bucks.
    You could even put the rod into the vice itself and use a piece of pipe for the former (see picture in the next post).
    Benjamin
ID:	3305 Please excuse my sloppy drawing.
    Benjamin
    Dec 2010
    Lake Stevens, WA
    EmptyNester-
    Thought about your post when I ran across this...
    http://www.pacifictrailers.com/Plast...e-steel-tubing
    i like it, nice finished product.
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
    Thanks Qubit & Jerky.
    MigPlazArc - I was digging around the junk drawer for a bolt the other day and ran across some u-bolts. I thought that either welding it or bolting it on the edge of the shelf might work well too.
    Hobart Handler 187
    Yeah, whatever works Make sure it will hold them all the way you want them to.
    Benjamin
    Looks Good
    "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and proclaiming, "WOW what a ride!!"
    Power Tig 225 LX
    Millermatic 252
    JD2 Model 32
    ..and a couple of BIG HAMMERS
    Brandon, this is Mickey and I have an engineering question on something I'm building and need some advice on positioning of a load arm on my device. Can you help me?
    Nice welding cart. Good way to save room in the shop by having two welders on one cart.
    Thanks.
    One thing I did that that worked out well was my wheel choice. It seems most commercial carts only have swivel wheels on one end. I put them on both ends and it really helps with manuverability in the garage (it's pretty tight on storage space).
    Hobart Handler 187
    I've bent up to 1/2" hardware store solid stock with a vice and a 4lb hammer. 3/8" you can make a nice hook out of without too much work. I have a hat hook I made to clamp on an argon tank with a 3/8" s hook. took about 10 minutes to bend it, I think. no heat, just hammer
    I like my torch hanger, though. it's way up high so the cable doesn't need to be looped to not drag on the ground when you roll it around. there's pics here: http://www.everlastgenerators.com/fo...r-welding-cart
    McGuire Irvine
    Crow Motor Co.
    Lincoln powermig 225 (work)
  1. First Project: Welding Cart
    By Glassbeaver in forum Other Custom Fabrications
    Last Post: 06-19-2014, 04:51 AM
  2. Yet another welding cart project!
    By HemiRod23 in forum Other Custom Fabrications
    Last Post: 06-26-2013, 09:10 PM
  3. Project #3 Another another Welding Cart
    Last Post: 02-17-2012, 07:22 AM
  4. Project 1 from Tritium, Welding Cart.
    By Tritium in forum Personal Projects (no welder required)
    Last Post: 01-07-2012, 09:12 PM
  5. welding cart/cooler project
    Last Post: 01-05-2012, 02:11 PM
