Results 1 to 5 of 5
Thread: Respirators?
    Sep 2011
    Middleburg Florida
    Default Respirators?
    Anyone use a respirator and what type? I'm not too worried about normal mild steel, but getting into stainless, galvanized, etc. has me thinking...
    Trip Bauer
    Former USN HT
    Everlast 200DX New Model
    Hobart Handler 125 MIG
    Van Norman #12
    Atlas 12" engine lathe
    I have not used one with welding but I would recommend one if your welding a lot of galvanized. I have welded that a couple times and even cleaning it with a grinder first doesn't seem to get it all.
    Sep 2011
    Middleburg Florida
    Yup, OD'd on zinc a number of times. Several welding fire fences in the junkyard out of old steel trusses and cut down light poles, and a few times in the Navy. Chugged much milk, but still felt like crap for a day or two, and remember the sick-sweet taste of my cigarettes. Getting older and hopefully wiser, I've started paying more attention to safety. Still have both eyes, all 10 fingers and most of my hearing, figure it was luck till now, but it'll be care from here on out.
    No recommendation on a type or cartridge? I found some $1000+ 3M auto dark/supplied air helmets, but that's a bit ridiculous.
    Trip Bauer
    Former USN HT
    Van Norman #12
    I just make sure i have good air circulation or an exhaust fan. I guess if I was breathing it in 40 hrs a week I'd probably go with a respirator.
    "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and proclaiming, "WOW what a ride!!"
    Power Tig 225 LX
    Millermatic 252
    JD2 Model 32
    ..and a couple of BIG HAMMERS
    i wear a north half mask. (http://www.masksnmore.com/no77hamaapr.html) with a p100 filter. i will wear it when im wleding, doing lots of grinding, torch cutting. your health should be number one priority. an inexpensive half mask will save you down the road big time.
    Journeyman welder
    250EX
    Power plasma 60
    horizontal band saw
