Thread: FCAW and Stick welding Sunday
    Default FCAW and Stick welding Sunday
ID:	3358I'm Getting better on the FCAW. There are 3 start/stops that you can hardly see. Click image for larger version.
ID:	3356 Oh 1/2 decent. Click image for larger version.
ID:	3363Another half decent weld. Click image for larger version.
ID:	3359WHAT IS THAT!?!! Must have been welding steel with a propane torch? Well this is what happens when you try to put two welds on top of the first one, to make it look better when you don't use enough amps or go slow enough because the blades are 1/16" and you have already burnt through them.
ID:	3360Click image for larger version.
ID:	3365 Well, now that I have already done it, I wish I would have done it different... I welded two angle pieces then welded those together. Made it harder for myself and it didn't turn out with square angles. When I do it again I will but joint two pieces then tack it on one side. Then I will tack the third one on the opposite side and I will grind the two original tacks off. Then I will tack the fourth one on and then I will finish welding it. Might try new thicker steel too.
    7018 stick welds: Click image for larger version.
ID:	3357 Getting better. Click image for larger version.
ID:	3364 Click image for larger version.
ID:	3361 Now I kinda like that one.
    Okay everybody... You know there are some things you just have to try to see what will happen lol
    This is what happens to 1/4" thick steel when you weld with a 1/8" 6011 rod that is meant for 125 amps at 140 lol. The last part of the weld (left to right) was a huge hole from it, but I managed to fill it in, at 140 amps, just barely...
    I would like to use this as my third project for the contest.
    Benjamin
    Try slowing down a little and getting that rod more vertical.
    "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and proclaiming, "WOW what a ride!!"
    Power Tig 225 LX
    Millermatic 252
    JD2 Model 32
    ..and a couple of BIG HAMMERS
    You need help, first off buy a grinder and weld on clean metal, welding on crappy metal gives spit back and crappy welds, second , you use less heat to fill a hole not more, third know your rod amperages ,125 amps for 1/8 6011 is too hot, fourth know your rod height above base metal, I have attached part of an earlier posting which may help you, as follows:
    To keep it simple for the newbie small amp welder, there are only 6 rods you need to know,6010, 6011, 6013,(the 60 series) and 7014,7018,7024 (the 70 series as I call them). Using 1/8 rods their midrange or starting amperage is as follows: 6010,6011,6013 = 100 amps. 7014,7018 =130 amps 7024 =160 amps
    For 3/32 rods 6010 = 50, 6011 = 60, 6013 = 70, 7014 =80, 7018 = 90, 7024 = 0 cause nobody makes such a small hard facing rod.
    Rod height above base metal, for the 60 series rods it can vary from 1/8 inch to 1/4 inch, On the 70 series it is 1/8 and less to a drag on the base metal.
    Amperage can vary from the midrange+ starting point by +\- 10 to 15 amps, all depends on your welder readout being accurate, length of welding cables, metal type and how clean the metal is.
    This information can be verified by reading up on the rod spec sheets supplied by Hobart or Lincoln.
    Hope this helps you.
    geezer
    geezer
    Hahaha Ja, I know what the rod amp range is, but like I said, just had to see... I was just filling the hole quick since there was a little rod left lol
    And the rod pack says 125 max... I was welding with 87-97 before... It's an old 295 amp ac something or another...Can't even see the brand lol
    Benjamin
    Quote Originally Posted by MigPlazArc View Post
    My apologies, misunderstood your situation, hopefully some newbie will read up on rod amps etc. and gain from our posting.
    Ja, and No problem...I'm kinda a newbie anyway
    Benjamin
  1. 200 dx welding stick problems
    Last Post: 03-02-2014, 04:42 PM
  2. Stick welding aluminum?
    By undercut in forum General Welder Questions
    Last Post: 05-13-2012, 11:48 AM
  3. Preheating to help Stick Welding
    By undercut in forum Stick Welding (SMAW)
    Last Post: 05-07-2012, 07:30 PM
  4. low amperage stick welding with PU 205
    By worntorn in forum Stick Welding (SMAW)
    Last Post: 05-03-2011, 12:21 PM
