Results 1 to 17 of 17
Thread: Ground Cable
    Default Ground Cable
    I ordered a 25' torch with my PP50 and expect it to show up soon.
    I'm assuming that it doesn't come with a ground cable - so I'll need to get a longer ground cable. When looking at ground cable size for welders, it's pretty big wire, but they run significantly more currect.
    So, two questions:
    1) What size cable is sufficient for a PP50 (it seems that 50 amps isn't all that much when compared to welders).
    2) Also, I've seen reference to "dinse" connectors (or something like that). Is that the connector type on the PP50 ground?
    Just starting in Aug '10
    Hobart Handler 187
    Just curious, why assume it comes without a ground cable? I looked on the PP50 spec page and while the ground cable is not in the list of included equipment, there is a picture of a ground cable below. I doubt Everlast would sell a machine with less than the standard configuration of parts, just as GM wouldn't sell a car with no tires. The photo shows a dinse connector on the ground clamp- similarly they'd include a cable diameter with enough scrote to do the job well. Are you thinking you'll need a ground cable with greater capacity?
    All of our units come with a ground/return cable. What I do is clip one to another (two together) for a longer clamp. But you can take the dinse off the one we ship and the clamp and add wire to get the length you like.
    Thanks Mike!
    I already have the unit. I am expecting an "add on" 25' torch.
    What is the minimum gauge wire you'd recommend?
    I had seen that you can get matching "dinse" connectors, so I thought I'd just make it like an extension cord.
    Thanks,
    Rege
    Hobart Handler 187
    The Boonies of Texas
    Personally I would use #6. YMMV.
    Thurmond
    Miller Bobcat 3 Phase,
    EVERLAST PowerUltra 205P
    What size is the ground cable supplied with the PP205? I would like to make an extension or just make a longer ground.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    I think they are around 10' or 12'. I have a spare I clamp on the end. But it's easy to make a longer one. Just re-use the ends.
    I meant what size is the cable #4, #6, 1/0 etc. and what size should I use for a 25' run. Does Everlast sell the ends by themselves? If so how much?
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    If you go #2, that's good for 200 amps at 50 feet. So plenty for 25 feet. Doing the math, You can go #4 at 25 foot, will work fine and save money. Copper is crazy these days. You can pay more for the thinner strands and more flex, but for a return clamp I would not bother. Not talked a TIG torch here.
    You will need to call sales to see what's in stock, we normally stock the dinse. The dinse can be found on the internet as well, the clamps, well all over.
    If you are making a new return cable assembly complete, I would get a nice clamp myself. You can get a fine clamp for $5-10, no joke. But the solid brass ones are nice, just do not go for the $80 ones. I think tweco is high at $45 myself.
    Feb 2012
    I'd use a good solid brass ground clamp with the #2 or #4 copper ground wire and this place has good prices on the dinse connectors.
    http://www.river-weld.com/Supply-cable-joint_c1697
    #2 or #4 it will be and I was planning on getting a brass clamp. The supplied clamp that came with my PP205 has worked great, no problems.
    X83 I have ordered plasma consumables from river-weld before on eBay (3shop-river) and the prices are great. I think it’s the same company.
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    Feb 2012
    Yes it's the same place and if you're just ordering on piece it might be cheaper to purchase on fleBay than on the web site.
    I will see where has the lowest price as I'm in no hurry. The dinse connectors are the 25 correct?
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
    Should be on the side of your dinse... the large ones say 35-70.
    The number I think changes (Ray and I joked about that quite a while back), but river-weld is the place and same guy. I have ordered consumables from him many times. Prices are great and everything worked. Shipping was not bad either.
    Of course always call our sales group first (877-755-9353), but I will vouch for river-welds myself if we do not have the part.
    Do not quote me on this, but should be good.
    Code:
    Gauge   50'     75'     100'     150'     200'
    #4      100A
    #3      150A
    #2      200A    150A    100A
    #1      250A+   200A    150A     100A
    1/0     350A    250A    200A     125A     100A
    2/0     400A+   300A    250A     150A     100A
    3/0     500A    400A    300A     200A     150A
    4/0     550A+   450A+   350A+    250A     200A
    Thanks Mike. What is the size that comes with the PP205?
    PowerPro 205
    9" South Bend Lathe
    Enco Mill/Drill
  1. HF Ground Bolt?
    By Jacobelps in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-08-2016, 04:38 PM
  2. 200DX Ground Cable
    By its_34 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-03-2013, 03:11 AM
  3. 1/0 15' Ground Cable W/Ends and 300 Amp Ground Clamp
    Last Post: 08-22-2012, 06:29 PM
  4. Switching out the ground cable.......
    By Steve in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 10-10-2011, 01:47 PM
  5. longer ground cable
    By acourtjester in forum Buy, Sale or Trade
    Last Post: 07-21-2011, 09:37 PM
