Results 1 to 8 of 8
Thread: Harbor freight air/hydraulic engine hoist conversion (flat bottom jack)
    Default Harbor freight air/hydraulic engine hoist conversion (flat bottom jack)
    Hey there, as with most people I like to save money where I can . Today's project consisted of modifying a $40 ( $32 with coupon) air/hydraulic flat bottom jack into the equivalent $80 jack for use on my engine hoist.
    $80 jack
    http://www.harborfreight.com/8-ton-l...ack-94562.html
    $40 jack
    http://www.harborfreight.com/8-ton-l...ack-95967.html
    The only differences between these two, at least that matter to me, is the flat bottom one is not a direct bolt in for my HF engine hoist. So I decided to use my HF bandsaw, cut off the old flange and weld it onto the new jack. Keep in mind I was not terribly worried about perfect penetration since this part will remain in compression under a load.
    Anyhow on to the pictures (forgive cell phone quality)
    Amazing that those tabs make it worth double the price.
    I probably would have been scared to weld directly to the jack and fabbed up a whole plate to bolt to the bottom, especially since I am so fond of drilling.
    redbeard- I actually considered doing something very similar, but the main reason I went the route I did is because I got a 1 year warranty with it and the lady said even if I set it on fire I can bring it back and get a new one lol. Also the $40 ram allegedly will sit about 1/2" higher (than the $80 one) so I didnt want to raise it anymore then I needed to, although I doubt it would of had any negative effects.
    Those bases are often cast iron, and not cast steel. I hope it holds. If its cast iron, it won't.
    Performance, I actually had not considered that..........I did a quick grind test and I think you might be right on it being cast iron. When I put the grinder to the base of the HF jack it produced yellow/orangeish sparks but when I grinded on some home depot steel next to me I got a very similar color but just a lot more spark.........and from my quick research this seems consistent with the grind tests of cast iron vs. steel.
    I suppose I should grind down the old welds and go back with a nickel N99 rod? Some posts mention stainless steel er308 works well also?
    I think you might use some non machineable cast rod, and it would be cheaper than N99.
    But welding cast is tricky and not for the average welder, particularly in a serious structural situation like this, where something can be life or death. To weld properly, you'll literally have to set the thing on fire, getting it hot enough to destroy all the internal seals, and cook the oil into sludge...then cool it slowly over a long period of time.
    I think I'd rather weld some fabricated steel ears on a flat piece of plate, drill the plate, and tap holes in the bottom of the jack, and affix it with bolts.
  1. Harbor Freight Welding Cart
    By Depdog in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 02-05-2018, 06:30 PM
  2. Upgrading a Harbor Freight 20 Ton Press
    Last Post: 06-11-2011, 04:14 PM
