Re: Wiring
Originally Posted by
Ed9
at 110V, it will run on a standard 20A breaker (rated 17-18Amp draw) BUT the machine output will be reduced by up to half. I would use at least a 30amp double pole @ 220vac since the machine can draw over 20amps at full power. Green is always ground (verify with a multimeter)
hmmm the manuals say: "you will be wiring 110v the same way as you wire the 220v. For units that have 110v capability, you will wire the two hot wires together to the hot lead."
no I don't work for everlast...
For 110volts. Green to ground. Blue to neutral, last wire to hot.
For 220volts. Green to ground. The other two wire go to the other two terminals in any order (color does not matter).
http://www.everlastwelders.com
http://www.everlastgenerators.com
