Thread: Project #4 from Trip - Lathe coolant guard
    Sep 2011
    Middleburg Florida
    Default Project #4 from Trip - Lathe coolant guard
    So I found a great coolant/lubricant for working stainless, SynKool. Water soluable, sump compatible, but I'm using it in a squirt bottle. Problem is, when you get within 2-3 inches from the chuck, it starts slinging it 3' out at low speed. A guard is in order, a curved one would be nice, but I want something easy to assemble, easily replaceable lexan panels, etc.
    Octagon!
    I'm using 3/4" angle I had laying around. After some measuring, I came to 14" diameter (is a 12" lathe) Still deciding on the width. Each side will be welded, the panels attached with two screws per side per panel.
    So far, pieces cut and mill scale removed. I'll be blasting them once they're welded.
    Left side
    Right side
    Sunday it'll get welded up and I'll figure out how to mount it to the lathe
    Trip Bauer
    Former USN HT
    Everlast 200DX New Model
    Hobart Handler 125 MIG
    Van Norman #12
    Atlas 12" engine lathe
    Looks like some clean work so far! Keep posting pics!
    Are you going to have a hinge to rotate the guard or flip up/ over the chuck?
    It may be nice to have it movable using a wing nuts or something to clamp it on the lathe so you can move it around. I had something machined the other day at work and the guard the lathe the machinist was using only protects the vicinity around the chuck, this would not be helpful if you were machining the end of a tube.
    Sep 2011
    Middleburg Florida
    Not done yet, but I got a couple hours of welding and grinding in today.
    Got them welded up, started cleaning them up past the welds
    Held up to see fitment
    Welded on some square tube to space and reinforce the front and provide a location to attach a mount in the rear
    I'm still trying to decide the best way to mount it, it should be easily removable for times when I'm not using the flood coolant. I'm thinking about a 3/4 square that slides into a 1" square and have that rigidly mounted. Should come either tomorrow or next week.
    yes, it occurred to me after burning/grinding/burning/grinding that I forgot to drill the holes to mount the lexan. I still need to sharpen a drill to drill the lexan properly, I'm thinking about drilling and tapping the frame rather than drilling through and using a screw and nut.
    Trip Bauer
    Former USN HT
    Van Norman #12
    Hi Trip59
    Great idea to cover lubricant sling but I would add another section of Lexan to cover the hand wheel from the dripping lubricant.
    Have fun
    Tom
    Everlast PM256
    Millermatic 180
    Longevity Force Cut 80I
    13" metal lathe
    Small Mill
    ect, ect.
    Sep 2011
    Middleburg Florida
    Tom, great idea, and I'll definitely look at it closer. The width and extension laterally from the face of the chuck mean that the handwheel is probably not going to wind up under it all the way. After reading your post and seeing your drawing, I think what I may do instead is put one that slants from right to left to direct the runoff like a gutter, towards the headstock. That would preserve the clearance needed for the compound and toolpost and direct it from the handwheel.
    Trip Bauer
    Former USN HT
    Van Norman #12
  1. Not really a project, but picked up the M100 motor guard
    By everlastsupport in forum Personal Projects (no welder required)
    Last Post: 09-02-2017, 05:56 PM
  2. Project 2 from Trip. Category: Welding Cart
    By Trip59 in forum Other Custom Fabrications
    Last Post: 03-10-2013, 03:55 AM
  3. Project 5 from Trip. Category: Metal Art
    By Trip59 in forum Metal Art
    Last Post: 01-12-2013, 04:37 AM
  4. Project 3 from Trip. Category: On Road Fabrication
    By Trip59 in forum On Road Fabrication
    Last Post: 12-10-2012, 02:48 AM
  5. Project 1 from Trip - new cart design (re-run contest)
    Last Post: 10-29-2012, 04:35 AM
