Results 1 to 6 of 6
Thread: filling a hole
    Default filling a hole
    Ok
    So a buddy of mine gave me a big pot from his restaurant to repair. It has a hole in the side near the top and is Aluminum. maybe 1/16 thick. How do I go about repairing the hole?
    Im new to tig and this is the second favor job I am doing the first was repairing an A/c line and that worked ok.
    Everlast I mig 205
    Everlast 200 amp spool gun
    Everlast 250 ex
    H. F. 12x36 lathe
    Grizzly Mill
    10,000 lb two post lift
    Box and Pan Brake
    Bead roller
    jet 5x7 horizontal band saw
    Mitec 50 A plasma cutter.
    tool grinder
    20 ton press and press brake
    70 Chevelle convert
    I don't have enough experience to answer your question, but I do have enough to ask you one more.
    How big is the hole you are filling??
    Everlast Powertig 225LX
    Harbor Freight O/A rig
    60 gal air compressor
    Do you any pics of the pot, was hole drilled or is there stress cracks around it? One thing I know is it has got to be clean and you may want to preheat to get good penatration.
    If this is for food prep, maybe that is a consideration in terms of material prep and filler selection.
    Why use TIG, you have a spoolgun and a mig, Tig is over rated for most jobs.
    Quote Originally Posted by revkev6 View Post
    about 1/4 to 3/8 dia
    Everlast I mig 205
    Everlast 250 ex
    H. F. 12x36 lathe
    Grizzly Mill
    Box and Pan Brake
    Bead roller
    tool grinder
    70 Chevelle convert
  1. Replies: 8
    Last Post: 12-05-2012, 05:04 AM
  2. Is there a bit to make a beveled hole?
    By DaveO in forum General Welding Questions
    Last Post: 04-21-2012, 04:49 PM
