Results 1 to 20 of 21
Thread: home-made weld positioner or plasma circle cutter
Threaded View
worntorn home-made weld positioner or... 03-03-2011, 07:14 PM
geezer Very good, I like it , you... 03-03-2011, 09:45 PM
deranged Any more pictures of the... 03-04-2011, 01:54 AM
ducksface I captured the pics so I... 03-04-2011, 05:00 AM
worntorn I'll take some pictures of... 03-04-2011, 06:11 AM
ScratchStart why don't you use one of... 04-28-2011, 07:15 PM
worntorn Here is a link to another... 03-05-2011, 12:58 AM
eide How do you attach the ground? 03-05-2011, 04:46 AM
worntorn I just clamp to the table and... 03-05-2011, 05:18 AM
WaWelder Thats a pretty swwet bit of... 03-19-2011, 07:36 PM
worntorn not a bit, that's why I put... 03-19-2011, 09:08 PM
jameswswanson Thats a really good Idea... 04-29-2011, 01:53 AM
worntorn no problem. I use the... 04-29-2011, 02:37 AM
welderdude I really need to build... 04-29-2011, 02:58 AM
Mikeymetal Brilliant! I have a 90 degree... 04-28-2011, 10:32 PM
Robert s Nice work good to see that... 03-19-2011, 10:48 PM
aaxiss great work Worntorn, I have a... 03-21-2011, 04:01 AM
worntorn thanks Don With the... 03-23-2011, 03:11 AM
aaxiss yea I cant wait for my 250ex... 03-23-2011, 04:34 AM
trickbiker If I could interject a... 10-14-2011, 02:37 PM
worntorn It didn't take long to build,... 06-22-2011, 02:17 AM
    Default home-made weld positioner or plasma circle cutter
    I made a weld positioner for doing circular tig welds. By mounting a pivoting arm on the base, I find that it works really well for cutting circles with the plasma cutter. Cost of the postioner was zero, all from junk under the bench. Power for the positioner is a small variable speed Makita cordless drill.
    Here I have cut a couple of 18" discs (both at once with the little Power Ultra 205 multi)for a custom drum I have to build. The drum will go into a new machine being built for a large bakery somewhere in Salt Lake City.
    Here is a link to a video clip of the cut http://www.youtube.com/watch?v=iI0qbNjLCHs
    Looks like 28 amps is the setting showing there, not bad for cutting 2 at once (3/16" ea.) which is much tougher than a single thickness of 3/8".
    Glen
Name:	plasma 2 001.jpg
ID:	931   Click image for larger version.
Name:	plasma 2 003.jpg
    Everlast PP256
    Everlast Imig 200
    Everlast Power Ultra 205
    P&H 400 amp A.C.
  1. Circle Cutter for iPT-60 Torch?
    By ebrandt in forum Everlast Plasma Cutters (PAC)
    Last Post: 09-05-2018, 10:24 PM
  2. Plasma Circle Cutter
    By In Utopia in forum Buy, Sale or Trade
    Last Post: 01-24-2013, 04:25 PM
  3. Need to plasma cut some circles/holes soon. Cheap magnetic circle plasma jig.
    By everlastsupport in forum Personal Projects (no welder required)
    Last Post: 05-15-2012, 03:06 AM
  4. Circle cutter recommendations
    By GreenGrass in forum Everlast Plasma Cutters (PAC)
    Last Post: 10-26-2011, 02:53 PM
  5. Home made rotisserie
    Last Post: 03-21-2011, 01:00 PM
