Thread: Plasma cutting 'table' on the cheap- way cheap.
    Dec 2010
    Lake Stevens, WA
    Default Plasma cutting 'table' on the cheap- way cheap.
    I'd love to have a big plasma cutting table, but no room. Still, I needed something for small brackets and such.
    I ordered this little (12") BBQ from Ace Hardware-$4.79, shipped FREE to my closest Ace- $5.20 w/tax. There's also an 18-incher for those big jobs.
    I cut out the center 2 rings of the grill so there would a big enough hole to avoid cutting the other rings, then put 'bout an inch of water in the bowl. Any more and it leaks out the leg holes...
    When I'm done cutting, I dump the water, give it a quick dry and hang it on the wall with all of the pieces inside. Like cash-flow in a business, floorspace is 'King' in a small garage.
    Silly? Probably. Dumb? Maybe. But, "It Worked For Me".
ID:	3751Name:  Ace82845.jpg
    HI qubit
    The main thing is (It works for me) Your the not the first guy that works on a shoestring.
    Posts like this makes others think and maybe they can come up with a simple solution that will work for them.
    Keep the gray matter working we all benefit from it.
    have fun
    Tom
    Everlast PM256
    Millermatic 180
    Longevity Force Cut 80I
    13" metal lathe
    Small Mill
    ect, ect.
    do you have any issues with the hot metal dross spitting water or shrapnel everywhere? cutting with a torch next to a puddle is a no-no, it throws hot little BBs around.
    McGuire Irvine
    Crow Motor Co.
    Lincoln powermig 225 (work)
    Dec 2010
    Lake Stevens, WA
    Hi, ogorir
    I hear ya.
    So far it's been OK. I've been testing outside and only with 1/16" sheet. Not wanting to get BB'd, I kind of work from the side until I see what the limit is.
    Good to bring that up so somebody doesn't try a something any heavier.
    Great idea for those small projects. I have also seen some place that mentioned using an old discarded gas BBQ for the same purpose. Bigger and bulkier but can be kept outside the shop with no ill effects . I love the threads where things are re-purposed by hobbyists to fit their needs, budget and space constraints. It helps everyone to as courtjester said use that gray matter
    Everlast I mig 205
    Everlast 200 amp spool gun
    Everlast 250 ex
    H. F. 12x36 lathe
    Grizzly Mill
    10,000 lb two post lift
    Box and Pan Brake
    Bead roller
    jet 5x7 horizontal band saw
    Mitec 50 A plasma cutter.
    tool grinder
    20 ton press and press brake
    70 Chevelle convert
    We have a sand bed in a burn table at work. I believe we also had a water bed on at least part of one at one time. Might be able to jsut used sand in the grill, no worries about leaking.
    Cool idea.
  1. Victor Propylene Cutting Tips Cheap
    Last Post: 08-22-2012, 06:20 PM
  2. Need to plasma cut some circles/holes soon. Cheap magnetic circle plasma jig.
    By everlastsupport in forum Personal Projects (no welder required)
    Last Post: 05-15-2012, 03:06 AM
  3. Welding/Plasma Cutting Table
    By scootarida1 in forum Hobyist Projects
    Last Post: 01-08-2012, 01:44 AM
  4. looking for cheap leads, any ideas?
    By dennis in forum General Welder Questions
    Last Post: 12-13-2011, 12:30 AM
  5. Sweet bookcase on the cheap!
    By ScratchStart in forum Personal Projects (no welder required)
    Last Post: 05-03-2011, 12:45 PM
